| PanelBilly |
Jul 11 2009, 11:33 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,948 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest
![]() There was a hole in the OEM board for clipping on what I think is the turn signal relay (the square one). Where do you clip it on when you switch to the new style board? |
| Engman |
Jul 11 2009, 11:48 AM
Zoisite ![]() ![]() ![]() Group: Benefactors Posts: 1,349 Joined: 25-March 03 From: New Albany, IN Member No.: 475 |
Here is a pic of the back of the stock fuse panel
| Engman |
Jul 11 2009, 11:49 AM
It looks like you have the intermittent wiper relay inside the cabin.
It normally mounts here Attached image(s)
| PanelBilly |
Jul 11 2009, 11:53 AM
There's five relays that have the rubber tree that press into the holes in the board. This box has a clip on it and in the original board there's a hole for it to clip on.
| Engman |
Jul 11 2009, 12:03 PM
You must have an optioned car - Give me a little time - week or so and I will send you a new cover panel with the 6 holes.
Mark |
| PanelBilly |
Jul 11 2009, 12:16 PM
![]() Its one of your panels, but I bought it from another member who bought it new and never installed it. Here's a photo of the OEM panel. The relay clipped in the two holes in the lower left corner |
| Engman |
Jul 11 2009, 12:40 PM
No problem - will get you a new cover panel and even include a ss brake resevoir strap for your issue. PM me your address.
And - if anyone else has had this issue - please contact me. Mark |
| 914Sixer |
Jul 11 2009, 06:36 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,434 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region
If the car is 72 or later the Turnsignal relay is mounted in the dashboard NOT on the relay plate.
| montoya 73 2.0 |
Jul 12 2009, 03:31 PM
Lack of consideration to others, and Selfish! ![]() ![]() ![]() Group: Members Posts: 1,791 Joined: 27-October 04 From: Paso Robles, Ca. Member No.: 3,016 Region Association: Central California |
Isn't the large black rectangular relay the turnsignal and the silver square one the dimmer relay? My Turnsignal relay is mounted under the dash on that lip next to the headlight switch.
Lo-Fi Version | Time is now: 15th March 2026 - 08:22 PM |
