Well i broke some bolts on my muffler, they were really rusty anyway |
buhs914 |
Jul 20 2009, 08:09 PM
Not So Newbie Group: Members Posts: 331 Joined: 16-June 09 From: Buckeye, AZ Member No.: 10,478 Region Association: Southwest Region |
ok so i was taking the muffler off before i drop the engine and 4 out of the 6 bolts that attach the muffler to the rest of the exhaust snapped. I guess i was hammering the wrench a little too hard lol (IMG:style_emoticons/default/smash.gif) I don't know what to do now.. maybe i should drill out the broken ones? our will i have to get another muffler? btw the 914 is a 1973 1.7L..
r_towle |
Jul 20 2009, 08:18 PM
Custom Member Group: Members Posts: 24,588 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
cut them off flush...drill them out (just a little bit more than 1/4 of an inch.
Buy threaded studs and weld them in place. That is how they are made. OR Buy a muffler. Rich |
buhs914 |
Jul 20 2009, 08:21 PM
ok cool. i'll go with the route that doesn't involve buying a new muffler. lol plus i enjoy a little more work..
Cap'n Krusty |
Jul 20 2009, 08:23 PM
"That is how they're made"? "Weld studs in"? Come on, Rich. The OE 1.7 mufflers are drilled and tapped for studs, and once you get the old ones out and the threads repaired, you just screw new studs into place. If you were to weld them, the weld would interfere with the gasket, and you'd be in a world of hurt.
For the person asking the question, penetrating oil and patience are your friends. WD40 IS NOT a penetrating oil. The Cap'n |
r_towle |
Jul 20 2009, 08:32 PM
the last one I fixed was welded in solid...I found it to be a stupid design.
I drilled a 1/2 inch hole around the top of the hole to allow for the weld to remain smooth with the face of the flange. Not something I run accross daily so I would assume Capn is right....see of you can get them out. Rich |
buhs914 |
haha yeah i kinda threw patience to the wind.. there's a thunderstorm moving in pretty fast and the dust storm before it is even faster. next time though i'll take my time lol but yeah sounds like a fairly easy job.. hopefully.. btw the name's Antonio lol
thtiming |
Jul 21 2009, 01:59 PM
Newbie Group: Members Posts: 6 Joined: 14-May 09 From: Valparaiso, IN Member No.: 10,364 Region Association: None |
A torch and some spray on wart remover works wonders on a rusted bolt. Heat it up, spray it with that cold wart remover, and the quick expansion/contraction usually shocks them loose.
buhs914 |
Jul 21 2009, 03:30 PM
ok so where can i get new studs?
Lo-Fi Version | Time is now: 7th June 2024 - 10:51 PM |
