Steering Bushing? |
Steering Bushing? |
RiqueMar |
Jul 25 2009, 09:12 PM
Enrique Allen Mar Group: Members Posts: 2,169 Joined: 28-August 08 From: San Diego, CA Member No.: 9,478 Region Association: Southern California |
Newbie question of the day....
Refering to the steering boot under the gas tank; is that a bearing that is in there, or a bushing? I see both on Pelican, but am not sure which I need. Thanks Rique |
ericread |
Jul 26 2009, 01:03 AM
The Viper Blue 914 Group: Members Posts: 2,177 Joined: 7-December 07 From: Irvine, CA (The OC) Member No.: 8,432 Region Association: Southern California |
Newbie question of the day.... Refering to the steering boot under the gas tank; is that a bearing that is in there, or a bushing? I see both on Pelican, but am not sure which I need. Thanks Rique There is a bearing inside a rubber assembly under the boot. I did some research on it last year, and it seems there is no direct replacement part for it. However, the good news is it's a very stout bearing, and they almost never fail. I removed mine, thoroughly greased it and re-installed it. Since then I have had no problems with it. The only real problem I had was that the old grease has solidified in the bearing, causing it to partially seize. After a thorough cleaning and re-greasing, it continues to work well for me. Good luck! Eric Read |
RiqueMar |
Jul 26 2009, 03:01 AM
There is a bearing inside a rubber assembly under the boot. I did some research on it last year, and it seems there is no direct replacement part for it. However, the good news is it's a very stout bearing, and they almost never fail. I removed mine, thoroughly greased it and re-installed it. Since then I have had no problems with it. The only real problem I had was that the old grease has solidified in the bearing, causing it to partially seize. After a thorough cleaning and re-greasing, it continues to work well for me. Good luck! Eric Read Ok, so it is the bearing that I need. They have it on Pelican, so that is all I needed to know, thanks! |
SirAndy |
Jul 26 2009, 01:07 PM
Resident German Group: Admin Posts: 41,675 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Ok, so it is the bearing that I need. They have it on Pelican, so that is all I needed to know, thanks! Post a link ... I'm pretty sure the bearing on pelican is for the steering column, not the rubber coupler ... (IMG:style_emoticons/default/shades.gif) Andy |
ericread |
Jul 26 2009, 05:01 PM
Ok, so it is the bearing that I need. They have it on Pelican, so that is all I needed to know, thanks! Post a link ... I'm pretty sure the bearing on pelican is for the steering column, not the rubber coupler ... (IMG:style_emoticons/default/shades.gif) Andy (IMG:style_emoticons/default/agree.gif) Like I said, I did a pretty thorough search some months ago and was unable to find a replacement part. Eric |
ellisor3 |
Jul 26 2009, 05:18 PM
HPWhore Group: Members Posts: 811 Joined: 23-October 08 From: Fleming Island, Florida Member No.: 9,683 Region Association: South East States |
Here is the number for the bearing:901.347.241.01
Here is the number for the coupling:901.347.201.02 and where you can find the bearing:http://pipes.yahoo.com/pipes/pipe.info?_id...l3RGTQFeGbbsjiw Here is the coupling: http://pipes.yahoo.com/pipes/pipe.info?_id...l3RGTQFeGbbsjiw |
RiqueMar |
Jul 27 2009, 12:17 PM
It goes here correct? I wasn't even aware anything went there.... (IMG:http://i16.photobucket.com/albums/b6/Emar06/IMG_0435.jpg) |
Lavanaut |
Jul 27 2009, 02:07 PM
Hungry Mind : Thirsty Gullet Group: Members Posts: 916 Joined: 20-June 06 From: Bend, OR Member No.: 6,265 Region Association: Pacific Northwest |
Here is the number for the bearing:901.347.241.01 Here is the number for the coupling:901.347.201.02 and where you can find the bearing:http://pipes.yahoo.com/pipes/pipe.info?_id...l3RGTQFeGbbsjiw You can't link directly to the results of the search unfortunately, you need to drop the part # into the search box and re-run it. Reid |
Lo-Fi Version | Time is now: 7th June 2024 - 01:31 PM |
