s.b. drplink bushing replacement, before i start |
rhodyguy |
Apr 2 2003, 08:06 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,085 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
did a search, perhaps used wrong terms. before i start fighting these things, should i just grind off one side of the bushing to ease removal? as for getting the new ones in, what's best. i'll be doing the fronts as well. thanks for keeping the frustration down to a level where i'm not throwing a wrench through a window and saving me a few hours i'm sure.
kevin |
Dave_Darling |
Apr 2 2003, 12:13 PM
Front or rear?
I've forgotten how the stock front droplinks go; but I think it was pretty straightforward. The rear droplinks were a bitch. The old ones pried out eventually; a slice in the bushing would have made that easier I think. The new bushings pressed in with a lot of persuasion, a vise, some screwdrivers (see "persuasion"), and a whoooooole lotta curse words (more "persuasion"). A good soak in hot water probably would have helped soften them and make them go in a bit easier. Putting them back on the car was also a pain; I used a carpentry-type clamp (bar clamp or squeeze-to-tighten clamp) to push them on. --DD |
Lo-Fi Version | Time is now: 2nd June 2024 - 01:27 PM |
