Randal |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,446 Joined: 29-May 03 From: Los Altos, CA Member No.: 750 ![]() |
Been runnng Falken Azenis (205 / 50 /R15's) on the 944 - which work great.
Really would prefer 225's, but they're not available in this tire. Any tire out the perform like the Azenis and come in 225 - 15's? |
grantsfo |
Arrrrhhhh! ![]() ![]() ![]() ![]() Group: Members Posts: 4,327 Joined: 16-March 03 Member No.: 433 Region Association: None ![]() |
Been runnng Falken Azenis (205 / 50 /R15's) on the 944 - which work great. Really would prefer 225's, but they're not available in this tire. Any tire out the perform like the Azenis and come in 225 - 15's? Hankook makes a 225/45/15 in their new S3 which is supposed to be better than Azenis. They are only 140 treadwear so should stick better than the Falkens. http://www.tirerack.com/tires/Sizes.jsp?ma...del=Ventus+R-S3 Beyond that there isnt much. Wide sizes in 15's are dying breed. This post has been edited by grantsfo: Aug 2 2009, 11:31 AM |
fasthonda |
914 Type R ![]() ![]() Group: Members Posts: 133 Joined: 10-January 04 From: Greenville, SC Member No.: 1,544 Region Association: None ![]() |
ghuff |
This is certainly not what I expected down here. ![]() ![]() ![]() Group: Members Posts: 849 Joined: 21-May 09 From: Bodymore Murderland Member No.: 10,389 Region Association: MidAtlantic Region ![]() |
Avoid hankook 15's in 225 unless you like sending tires back and adding tons of weight.
I mounted them myself at the shop, lined up the valve stems proper and still had to send 2 tires back to tirerack because they required way too much weight to balance out. The two I received back were borderline but better. Hankook has some poor quality control. But beyond that I am in this boat my daily driver I run 225/50/15 because 400hp and FWD needs a wide foot print. |
PeeGreen 914 |
Just when you think you're done...wait, there is more..lol ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,219 Joined: 21-September 06 From: Seattle, WA... actually Everett Member No.: 6,884 Region Association: Pacific Northwest ![]() ![]() |
Been runnng Falken Azenis (205 / 50 /R15's) on the 944 - which work great. Really would prefer 225's, but they're not available in this tire. Any tire out the perform like the Azenis and come in 225 - 15's? Toyo RA1 and R888 come in 225/45-15 (IMG:style_emoticons/default/agree.gif) Way better than Azenis in my opinion. |
Chris Hamilton |
Senior Member ![]() ![]() ![]() Group: Members Posts: 611 Joined: 7-March 06 From: Berkeley, CA Member No.: 5,687 ![]() |
I just got some Toyo RA1s in 225/50R15 for my 914. I'll let you know how those work out.
A 914 I recently bought had Nitto 275/50 R15 555Rs on it. I hear they hook up very well in a straight line, I don't know about the cornering performance though. |
race914 |
73 914-4 ![]() ![]() ![]() Group: Members Posts: 1,006 Joined: 31-October 05 From: Nipomo, California (Central Coast) Member No.: 5,027 Region Association: Central California ![]() |
Randal,
Here are Toyo R888 225/45-15s on 8s ![]() ![]() |
nolift914 |
Autoxer ![]() ![]() Group: Members Posts: 183 Joined: 24-May 09 From: Rockaway Beach NY Member No.: 10,399 Region Association: None ![]() |
I am currently running Nitto NT1's 225/45/15 on 8x15's, on my 85 944na
They were a huge improvement from kuhmo 700's, they have a 100 tread rating and I found them for $140 http://www.discounttiredirect.com/direct/t...e&tmn=NT-01 Attached image(s) ![]() |
grantsfo |
I am currently running Nitto NT1's 225/45/15 on 8x15's, on my 85 944na They were a huge improvement from kuhmo 700's, they have a 100 tread rating and I found them for $140 http://www.discounttiredirect.com/direct/t...e&tmn=NT-01 Do they make the NT05 street tire in a 225? That might be a good option for those who want to stick with streets. Issue I have with DOT R's and california roads is that they pickup sharp stuff and puncture more often. |
nolift914 |
I am currently running Nitto NT1's 225/45/15 on 8x15's, on my 85 944na They were a huge improvement from kuhmo 700's, they have a 100 tread rating and I found them for $140 http://www.discounttiredirect.com/direct/t...e&tmn=NT-01 Do they make the NT05 street tire in a 225? That might be a good option for those who want to stick with streets. Issue I have with DOT R's and california roads is that they pickup sharp stuff and puncture more often. The nitto nt05 start at 17's, although the nitto nt01 are DOT r's the have a 100 tread rating which is high for a R, One of the reasons I chose them, was so I could drive them to the Autox's. I guess it all depends on how the car is being used, just my two cents. (IMG:style_emoticons/default/smile.gif) |
nolift914 |
If you are looking for a non r-compound tire, another choice are toyo r1r's
the got a good write up in GRM 6/09 they have a tread wear rating of 140 http://www.tiresdirect.net/TOYO_Proxes_R1R...9bb156021315842 |
grantsfo |
If you are looking for a non r-compound tire, another choice are toyo r1r's the got a good write up in GRM 6/09 they have a tread wear rating of 140 http://www.tiresdirect.net/TOYO_Proxes_R1R...9bb156021315842 there you go! |
Lo-Fi Version | Time is now: 16th June 2024 - 07:19 PM |
