| sixaddict |
Aug 5 2009, 09:42 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,061 Joined: 22-January 09 From: Panama City Beach, FL Member No.: 9,961 Region Association: South East States
Newly painted car has glass with apparent water spots that seem permanent. There must be a trick........So how can I revitalize glass so it looks as nice as the paint. Thanks,
Terry |
| Heeltoe914 |
Aug 5 2009, 02:58 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,135 Joined: 31-January 06 From: Tujunga Calif, Member No.: 5,506 |
Great Question ????
(IMG:style_emoticons/default/popcorn[1].gif) |
| Krieger |
Aug 5 2009, 10:21 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,855 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None
I just went through this with a side window I just bought. I tried all the common ones like vinegar CLR, something else I bought at the supermarket. I tried something like turtle wax. Nothing worked. I got a product called AMAZ clean and green water stain remover at Ace Hardware. It is a mild abrasive. It took 4-5 applications and a ton of elbow grease to get them off, but it worked.
| turboman808 |
Aug 6 2009, 11:51 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,718 Joined: 31-January 06 From: North Jersey Member No.: 5,505 Region Association: North East States |
I bought a glass cleaning system from griots. It does a pretty good job but if it's got serious pitts in it you might not be able to repair it.
I was able to remove etching from dirt and the wipers. |
| 70Sixter |
Aug 6 2009, 12:16 PM
Member ![]() ![]() Group: Members Posts: 422 Joined: 3-August 04 From: Surf City, NC Member No.: 2,444 Region Association: South East States |
| Katmanken |
Aug 8 2009, 01:27 PM
You haven't seen me if anybody asks... ![]() ![]() ![]() ![]() Group: Members Posts: 4,738 Joined: 14-June 03 From: USA Member No.: 819 Region Association: Upper MidWest |
Ya sure those spots are water?
If you splash Ospho deruster or another strong acid on glass, it will etch it. |
| jimmybryan |
Aug 8 2009, 03:33 PM
Newbie ![]() Group: Members Posts: 2 Joined: 22-April 09 From: kutztown, pa Member No.: 10,288 Region Association: North East States |
Hello Terry,
Fellow noob Jim here. Years ago I sold a product for that, Phantom Chrome and Glass Clnr, I'm no longer afilliated but I did a quick search and found it here, you may find it closer to home if you do a more detailed search ......... http://www.highwayshine.com/dbID/459.html; It was basically jewler's rouge and alcohol, I can attest to it's ability to polish normal glass surfaces but never tried it on anything that was etched. I think I'd first try a fresh razor scraper (like your mechanic uses to remove inspection stickers) to decide if it's a surface deposit or etch. If it's on the surface I've also heard of using #0000 steel wool with soapy water. Just don't use scotch brite pads (don't ask me how I know (IMG:style_emoticons/default/huh.gif) ). |
| sixaddict |
Aug 18 2009, 01:02 PM
Some great help here....Thanks !! Sorry just realized I posted this in the wrong forum.....I will report results.
TOT |
| sixaddict |
Aug 25 2009, 03:46 PM
Great results !
I took the cheapest route to see if it would work. i.e Trying JimmieB's suggestion for Phantom Chrome and Glass cleaner but had to resort to 0000 steel wool ( which is secondary instruction if cloth doesn't work). Tried on rear window and it did a good job. The glass is sparkling answering my proverbial question....how did he get those windows so clean. Went to highway shine web site ....pretty painless. Thanks again to all who contributed........Spending so much on this baby I decided to try cheap angle and finally got to one that worked. TOT |
| PRS914-6 |
Aug 26 2009, 08:42 AM
Excellence Magazine Project 914 3.6 ![]() ![]() ![]() Group: Retired Members Posts: 1,278 Joined: 20-May 06 From: Central California Member No.: 6,031 Region Association: None |
There is a product called Nothin's Better and at least out west you can find it at auto parts stores and hardware stores. It's inexpensive and works great. It's a powder you use on a damp cloth. I have even used it to clean entire shower doors with my electric buffer. Great product for the money.
| Sleepin |
Aug 26 2009, 09:18 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,647 Joined: 20-November 07 From: Grand Junction, Co. Member No.: 8,357 Region Association: Rocky Mountains |
I have heard recommendations of using Bartenders Friend. It is similar to AJAX but less abrasive.
| underthetire |
Aug 26 2009, 11:03 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,062 Joined: 7-October 08 From: Brentwood Member No.: 9,623 Region Association: Northern California |
Hey, found a use for that Sham-Not-So-Wow ! They soak up spilled coffee under your feet AWESOME. (IMG:style_emoticons/default/headbang.gif) |
| Drums66 |
Aug 26 2009, 03:45 PM
914 Rudiments ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,321 Joined: 15-January 03 From: Coronado,Cali Member No.: 151 Region Association: Southwest Region |
Great results ! I took the cheapest route to see if it would work. i.e Trying JimmieB's suggestion for Phantom Chrome and Glass cleaner but had to resort to 0000 steel wool ( which is secondary instruction if cloth doesn't work). Tried on rear window and it did a good job. The glass is sparkling answering my proverbial question....how did he get those windows so clean. Went to highway shine web site ....pretty painless. Thanks again to all who contributed........Spending so much on this baby I decided to try cheap angle and finally got to one that worked. TOT 00 fine steel wool! (IMG:style_emoticons/default/idea.gif) |
Lo-Fi Version | Time is now: 30th April 2026 - 02:32 PM |
