Fuel Relay Problems, Help |
Jaymann |
Aug 20 2009, 12:03 PM
Member Group: Members Posts: 140 Joined: 18-August 09 From: Drexel hill pa Member No.: 10,692 Region Association: None |
Hi all:I am new here.I have a fuel relay problem.I have a 1975 porsche 914 1.8 L F.I. 4 CYL. THE OLD RELAY IS PART# 022 906 059. The new relay is part # 071906059AO.E.M.IT DOES NOT FITT THE FUEL CONN.My fuel conn is black and the comp conn is white.The new connector is a 13 pin,the old was only 11 pin.The fuel side will not fitt the connector.Is this a bastrd conn or the wrong relay???They claim it is right; but I looked up the part and it says its for a CA vanagan can this be modified to work???I need some good advice Jason
dr914@autoatlanta.com |
Aug 20 2009, 12:11 PM
914 Guru Group: Members Posts: 7,869 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
Hi all:I am new here.I have a fuel relay problem.I have a 1975 porsche 914 1.8 L F.I. 4 CYL. THE OLD RELAY IS PART# 022 906 059. The new relay is part # 071906059AO.E.M.IT DOES NOT FITT THE FUEL CONN.My fuel conn is black and the comp conn is white.The new connector is a 13 pin,the old was only 11 pin.The fuel side will not fitt the connector.Is this a bastrd conn or the wrong relay???They claim it is right; but I looked up the part and it says its for a CA vanagan can this be modified to work???I need some good advice Jason part number mix up in the bosch book. Typical. Just like the sr 17x vs sr 15x starter mixup. |
Drums66 |
Aug 20 2009, 02:53 PM
914 Rudiments Group: Members Posts: 5,321 Joined: 15-January 03 From: Coronado,Cali Member No.: 151 Region Association: Southwest Region |
Hi all:I am new here.I have a fuel relay problem.I have a 1975 porsche 914 1.8 L F.I. 4 CYL. THE OLD RELAY IS PART# 022 906 059. The new relay is part # 071906059AO.E.M.IT DOES NOT FITT THE FUEL CONN.My fuel conn is black and the comp conn is white.The new connector is a 13 pin,the old was only 11 pin.The fuel side will not fitt the connector.Is this a bastrd conn or the wrong relay???They claim it is right; but I looked up the part and it says its for a CA vanagan can this be modified to work???I need some good advice Jason part number mix up in the bosch book. Typical. Just like the sr 17x vs sr 15x starter mixup. Exactly..........probably gave you one for a 74'' same thing happen's for AFM's 6 and 7 pin...........Later! (IMG:style_emoticons/default/idea.gif) |
Jaymann |
Aug 20 2009, 05:50 PM
Here are some clues,help me solve the mystery.Here are some pics of the connectors, and the new and old relay.Is this fuel connector oddball???I actully got this old relay to work,after some mcivor action and alot of contact cleaner.And it fits the connector.I also searched 35 years of the vehicle history and there is no metion of any replacement of the relay or conn.The company I BOUGHT the relay from says its right, go ahead and jump it out ,and see if you have function.This seems like a bad idea to me.I find it hard to believe after seeing the vehicle histry book,that includes the original bill of sale and the window sticker.Plus all service records, that this was forgotten. But anything is possible Jason
Jaymann |
Aug 20 2009, 05:58 PM
sorry I tryed to load up some pics
Lo-Fi Version | Time is now: 22nd May 2024 - 08:46 PM |
