| jays914 |
Sep 10 2009, 05:21 PM
Newbie ![]() Group: Members Posts: 14 Joined: 25-June 09 From: East Liverpool Ohio Member No.: 10,507 Region Association: None |
See additional pictues posted 9/15/09 Everyone, I would like to know how much of a problem it would be to take 1.7 914 FI engine and convert it to a carbs to put into a Bradley GT project car. The body kit is an original 1976 model that was never put together. The Bradley was purchased by my cousin and I have the spare engine. The engine (in a barn for the last 15 years) will be torn down for inspection and parts replaced as needed. Thought this would be a good way to reuse the 1.7 since most of the other comments I have heard or read for this type of engine were less than favorable. Should the engine get a big bore kit, cam, dist, low pressure fuel pump? If so, does anyone have the required parts for the conversion? How much? Thanks for your input! Jays914 |
| dlo914 |
Sep 10 2009, 06:35 PM
Whatchu' lookin' at?!?! ![]() ![]() ![]() ![]() Group: Members Posts: 3,433 Joined: 6-September 04 From: San Gabriel, CA Member No.: 2,697 |
You could up the size by going with 96mm pistons and the total CC's will come to 1988 and you will need a 2.0l crank and rods (IIRC) . And since you're going with carbs you're gonna need a different cam. Also since you're tearing down the engine might as well have the heads port n polished.
Correct me if i'm wrong. Others should be putting in their own advice soon. |
| SLITS |
Sep 10 2009, 06:41 PM
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
If you are asking if it will fit ... I have no idea .... they were fugly kits anyway.
| VaccaRabite |
Sep 10 2009, 06:47 PM
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,845 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region
Thought this would be a good way to reuse the 1.7 since most of the other comments I have heard or read for this type of engine were less than favorable. Should the engine get a big bore kit, cam, dist, low pressure fuel pump? If so, does anyone have the required parts for the conversion? How much? Hi Jay, sounds like a cool project. Got any pictures of the kit? if you have a 1.7, it is pretty easy to turn it into a 1911 using a lot of the parts you have on hand. You will want a new cam, and you will need to have head work done by someone competent. The 1911 used the stock 1.7 crank and case. Heads will need to be flycut to accept 96mm cylinders while they are checked out for cracks, seats and valves. You will need to source 96mm pistons and cylinders. I used 2L cylinders and had them bored out to 96, and used 96mm Keith Black flat top pistons. For the cam, you are going to want to change a lot of the valve train. You will have to cut new pushrods, you will need new lifters (that match the cam). You already have the desired 1.7 rockers, so it will be an easy move to go to the Elephant foot valve arms. Jake Raby's cam kits are pricey, but they will come with all the stuff you need, and he or Blake will work with you to choose the best cam grind for your application. Or, you can call Web. Cheaper, and be sure to buy the matching lifters or cam life will be reduced. All in all, figure probably around $2K-$3K to build the engine when you have accounted for head work, balancing, parts, etc. OR. Call (okay, PM) McMark and ask about his $5K plug and play 2056. He builds it, you bolt it in. Its a pretty sweet deal. Zach |
| jays914 |
Sep 13 2009, 02:31 PM
Hey guys thanks for the great input!
I'll post some picture of the project very soon. We are thinking of keeping th FI on the engine since I have all of the parts from a dismantled 1971 914 including the wiring harness, fuel pump, and relay box. Just thinking today that a 1.7 in good condition (pending inspection/rebuild) will be more than enough engine to power the GT project. Thanks again (IMG:style_emoticons/default/piratenanner.gif) Jays914 |
| Dave_Darling |
Sep 13 2009, 07:37 PM
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,338 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California
The 96es will make for the 1911cc engine, not 1988. The 96es that fit into the recess in the 1.7 heads are super thin, and it's a much better idea to get the heads cut for the larger-diameter cylinders--the 96es made for 1.8s and 2.0s have much more meat on them.
I would be very tempted to just swap over the fuel pump and stick the carbs on and go. (Don't use a single carb setup, it works poorly on these motors.) It'll be very quick and very cheap, and you should know pretty early on if you really do need to open up the motor. Once you open it up, it gets very easy to spend big $$$$ on "while you're in there" items.... --DD |
| jays914 |
Sep 13 2009, 08:31 PM
Dave,
Yet more great advise..... Thanks! Jays914 |
| jmill |
Sep 13 2009, 09:07 PM
Green Hornet ![]() ![]() ![]() ![]() Group: Members Posts: 2,449 Joined: 9-May 08 From: Racine, Wisconsin Member No.: 9,038 Region Association: Upper MidWest |
I believe the Bradley was built on a bug pan. I've never done a TI to TIV swap. Talk with Jake. He'll know what you need. You might even need to go with DTM cooling.
http://www.aircooledtechnology.com/store/p...at=0&page=1 |
| bfrymire |
Sep 13 2009, 09:54 PM
Salsaholic ![]() ![]() ![]() Group: Members Posts: 590 Joined: 1-August 04 From: Sunnyvale, CA Member No.: 2,431 Region Association: Northern California |
Everyone, I would like to know how much of a problem it would be to take 1.7 914 FI engine and convert it to a carbs to put into a Bradley GT project car. The body kit is an original 1976 model that was never put together. The Bradley was purchased by my cousin and I have the spare engine. The engine (in a barn for the last 15 years) will be torn down for inspection and parts replaced as needed. Thought this would be a good way to reuse the 1.7 since most of the other comments I have heard or read for this type of engine were less than favorable. Should the engine get a big bore kit, cam, dist, low pressure fuel pump? If so, does anyone have the required parts for the conversion? How much? Thanks for your input! Jays914 Hello Jay, A co-worker/friend has one of these, and drives it to work fairly often. I will see if he can offer some help. BTW, he put a Porsche 911 motor in his, and he had to do some modifications to get it to fit. -- brett |
| VaccaRabite |
Sep 14 2009, 12:43 PM
(I know this is not Jay's car. Well, maybe it is, but probably not)
(IMG:http://www.sunsetclassics.com/1978-vw-bradley/images/1978-vw-bradley.jpg) Neat looking car. Kinda like an Opel GT did it with a VW dune buggy. I'd drive it, and a T4 would power it quite nicely (and look better then the tiny VW exhaust too). But I am even more interested in the girl.... Zach |
| Cap'n Krusty |
Sep 14 2009, 12:51 PM
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California |
You're gonna need a conversion flywheel and a clutch suitable for the tranny. They're pretty readily available. The Cap'n
| jays914 |
Sep 15 2009, 07:46 PM
More pictures 9/15/09
Attached thumbnail(s) |
| jays914 |
Sep 15 2009, 07:49 PM
Yet another picture 9/15/09
| jays914 |
Sep 15 2009, 07:52 PM
One last picture for today 9/15/09
| VaccaRabite |
Sep 15 2009, 08:10 PM
Since you already have a 914 engine, why not use a 901 transmission? Out of an early 911. I think that would bolt right up to the engine, and it would give you a 5 speed.
Zach |
| jays914 |
Sep 15 2009, 09:00 PM
Since you already have a 914 engine, why not use a 901 transmission? Out of an early 911. I think that would bolt right up to the engine, and it would give you a 5 speed. Zach Zach, More questions.... Will the 901 trans fit into the VW pan? What would be a fair price for the setup? Will the shifter and associated parts need to be purchased and added to the project? Sorry for all the questions. We would like to do it right at the best price..... Thanks! Jay |
| VaccaRabite |
Sep 15 2009, 09:37 PM
Jay,
All I can say is that it has been done. You may have to fabricate some sort of mount. There may even be one on the market. If you have the skills needed to do this kind of a kit though, you've got the skills needed to weld up a tranny support bar. Looks like you have a fair bit of welding to do anyway. Zach |
| Dave_Darling |
Sep 15 2009, 09:38 PM
It will fit with some beating, and maybe a little grinding and welding.
You'll need the shifter bits, and you may have to make up a linkage. --DD |
| jays914 |
Sep 17 2009, 01:06 PM
Zach and Dave,
Thanks for the latest info! As you guys know that $$$ is always a consideration when doing this kind of project. We are looking for the best compromise. Should we trick it out with a built-up Porsche engine/trans combo or just go with the stock VW parts for now??? My cousin has 2 pipe buggies and another VW pan plus a number of VW engines and transmissions. He also has a very low miles Kia 4 cylinder engine (wrecked car) and complete wiring harness. The main problem with this type of engine is no one makes a conversion kit that we can find. The current flywheel is for an automatiic transmission. The flywheel is close to the Porsche 914 in size and number of bolts to the crankshaft. I think we could have a flywheel machined to match the bolt pattern. We would have to fab an adaptor plate to mount the engine to the transmission. Then mounting a rad/fan and all the other junk... BTW...VW pans are going to be welded together tonight by a professional welder, then the mounting of the body should come pretty soon, can't wait to see it as a roller.... (IMG:style_emoticons/default/bye1.gif) Jay |
| r_towle |
Sep 17 2009, 01:24 PM
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States
Stick with all beetle parts...it will be easier.
The car is gonna weigh what....1300 lbs...a standard beetle motor/trans will scare the hell out of you. Rich |
Lo-Fi Version | Time is now: 16th April 2026 - 11:40 PM |
