914 rear breaks, sticky |
svsv |
Oct 10 2009, 11:37 AM
Newbie Group: Members Posts: 8 Joined: 26-September 09 From: NC USA Member No.: 10,851 Region Association: None |
I'm new to 914s but been a car guy for along time but thies rear breaks seem to be stumping me (IMG:style_emoticons/default/WTF.gif) I set them up per tech artical but it seems the pressure is not bleeding off cuz i can open the bleeder and they free right up anybody know whats up?
IronHillRestorations |
Oct 11 2009, 07:14 AM
I. I. R. C. Group: Members Posts: 6,728 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
You need to replace the rubber flex lines have deteriorated and are acting like a check valve. Very common. I just had a car in my shop with the same problem.
Over time the brake fluid breaks down the rubber and the inside of the hose clogs up. There's enough mechanical advantage from the master cylinder to push fluid to the caliper, but it will hold the brake fluid on that part of the hydraulic circuit under pressure. From the exterior the hose doesn't look bad, but it is toast. |
svsv |
Oct 11 2009, 08:34 AM
You need to replace the rubber flex lines have deteriorated and are acting like a check valve. Very common. I just had a car in my shop with the same problem. Over time the brake fluid breaks down the rubber and the inside of the hose clogs up. There's enough mechanical advantage from the master cylinder to push fluid to the caliper, but it will hold the brake fluid on that part of the hydraulic circuit under pressure. From the exterior the hose doesn't look bad, but it is toast. hey thanks alot it didn't even cross my mind but that makes perfect sence |
Lo-Fi Version | Time is now: 7th June 2024 - 07:44 AM |
