Bumper Top, studs are broken off |
tradisrad |
Oct 11 2009, 07:47 PM
Senior Member Group: Members Posts: 985 Joined: 11-September 06 From: San Mateo, CA Member No.: 6,815 Region Association: Northern California |
I've got a bumper top that is in good shape with the exception of some broken studs. I did a search to try and find information on repairing these studs and I became impatient with the search results. So I am starting a new thread.
I would like to know what the common fix for broken bumper top studs is. thanks -Rob |
dr914@autoatlanta.com |
Oct 11 2009, 07:56 PM
914 Guru Group: Members Posts: 7,869 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
I've got a bumper top that is in good shape with the exception of some broken studs. I did a search to try and find information on repairing these studs and I became impatient with the search results. So I am starting a new thread. I would like to know what the common fix for broken bumper top studs is. thanks -Rob mount it and put a sheetmetal screw up into it or drill it and install another stud. |
tradisrad |
Oct 11 2009, 08:22 PM
thanks, my inital thought was to drill and re-tap it. How far into the pad does the stud go?
thanks again -Rob |
bandjoey |
Oct 11 2009, 11:05 PM
bandjoey Group: Members Posts: 4,926 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
drill oversided and epoxy a bolt or threaded sleve into the rubber
Gint |
Oct 12 2009, 08:07 AM
Mike Ginter Group: Admin Posts: 16,075 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
The first two threads (after yours) in this search look pretty good.
link for 914world search of terms "+broke* +bumper +pad +stud" |
Mikey914 |
Oct 13 2009, 01:34 AM
The rubber man Group: Members Posts: 12,671 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Drill it and epoxy a stainless stud in. If the top and corners are good, it should last a few more years easy.
tradisrad |
Oct 13 2009, 07:58 AM
Top is in good shape, so It only needs new studs. Thanks for the replies.
Gint |
Oct 13 2009, 08:33 AM
The first two threads (after yours) in this search look pretty good. I didn't realize it but my link was broken. I've since fixed it.Have a look at the first two threads after yours in this search link. Good info...link for 914world search of terms "+broke* +bumper +pad +stud" |
rfuerst911sc |
Oct 13 2009, 05:52 PM
Advanced Member Group: Members Posts: 2,158 Joined: 4-May 06 From: Dahlonega , Georgia Member No.: 5,980 Region Association: South East States |
The item you want to use is called a hanger bolt. It is a lag thread on one end and a machine thread on the other. They come in different diameters and lengths. Drill out the best you can the broken stud. Purchase some of these hanger bolts the correct size or as near as you can get. Mix up some JB Weld or epoxy of your choice and coat the coarse threads of the hanger bolt. Screw it into the hole and let it dry. Should last a long time.
bandjoey |
Oct 13 2009, 06:14 PM
And you can shop our wonderful member Mikey914rubber. (IMG:style_emoticons/default/biggrin.gif)
Mikey914 |
Oct 14 2009, 02:08 AM
It is OEM, so drive it in the rain and it's only a matter of time. (IMG:style_emoticons/default/biggrin.gif)
Lo-Fi Version | Time is now: 23rd May 2024 - 07:50 AM |
