Clutch or engine mount? |
RonnieJ |
Oct 31 2009, 04:28 PM
RonnieJ Group: Members Posts: 230 Joined: 16-June 03 From: Sterling Heights, Michigan Member No.: 829 Region Association: Upper MidWest |
I know this is going to be a very stupid question to most of you but here I go. My 914 was in storage a long time and now that I have it out when I put it into gear by the way no gringing when I shift into any gears it shakes when I let out the clutch in first gear. Do you think I have a broken engine mount or some type of fluid on my clutch or a little corrosion or rust from it setting (IMG:style_emoticons/default/confused24.gif) ? Also is it real obvious if I have a broken mount or do I need to remove the mounts to check. Thanks in advance for the info.
914Sixer |
Nov 1 2009, 08:50 AM
914 Guru Group: Members Posts: 8,908 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
If it is shaking, I would say you have broken motor mounts or transmission mounts.. What year is it?
ClayPerrine |
Nov 1 2009, 08:52 AM
Life's been good to me so far..... Group: Admin Posts: 15,527 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
The clutch could be the problem if it is chattering when you let it out. Usually, on a broken side shifter mount, the gear lever will move when you let out the clutch.
detoxcowboy |
Nov 1 2009, 09:01 AM
Senior Member Group: Members Posts: 1,294 Joined: 30-January 08 Member No.: 8,642 Region Association: Africa |
Just a heads up when I had a broken motor mount you can fell then engine lurch backwards clunk little when you take off in first every time but my shifting was not messing up, I drove it like that for 6 weeks so I got the feeling down but always shifted well, on top of that my tranny mounts were old and shot still never caused what your describing.. Oh and without taking the mounts out it is not really visibly discernible, especially tranny mount appear good but the rubber is shot, my motor mount was sheared in 2 but could not see that until I was taking it out. My $$$ is on a clutch issue..
ClayPerrine |
Nov 1 2009, 09:04 AM
I have seen LOTS of 914s with the front motor mounts broken on the side shifter. It doesn't cause shifting problems, but the shifter moves when you take off....
IronHillRestorations |
Nov 1 2009, 09:07 AM
I. I. R. C. Group: Members Posts: 6,732 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
Put the parking brake on, and have someone watch the engine as you let out the clutch (in gear). If you have a broken mount the engine will move much more than it should.
Lo-Fi Version | Time is now: 13th June 2024 - 07:04 PM |
