Front Caliper Reassembly |
Strudelwagon |
Oct 31 2009, 07:06 PM
Member Group: Members Posts: 411 Joined: 11-October 08 From: interior, British Columbia Member No.: 9,633 Region Association: Canada |
Hi, Looking for some advice on reassembly of my 2 bleeder ATE front Calipers.
Got everything apart, drilled out the two broken caliper half bolts and found two 12.9 grade replacements. Everything is painted and i'm waiting on caliper half seals from Eric Shea. Question... while test fitting the pistons I come up against some resistance from the inner piston pilot that slides on the center pin thats attached to the caliper bore. Whats the deal? do you just force it on with a C-clamp? (IMG:style_emoticons/default/WTF.gif) Thanks Steve |
davep |
Oct 31 2009, 07:17 PM
914 Historian Group: Benefactors Posts: 5,145 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
Yes, using a clamp will work fine. It should not take much force, just more than you can apply with your fingers alone.
Strudelwagon |
Oct 31 2009, 07:28 PM
Eric_Shea |
Nov 1 2009, 01:34 PM
PMB Performance Group: Admin Posts: 19,275 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
Make sure you have the orientation of the pad step correct first.
Strudelwagon |
Nov 1 2009, 05:39 PM
Lo-Fi Version | Time is now: 23rd May 2024 - 04:16 AM |
