74 2.0 stalls, 74 2.0 stalls on take off w/ new weber 32/36 & vacum dist |
Robert Blackmon |
Nov 1 2009, 07:17 PM
Newbie Group: Members Posts: 1 Joined: 12-October 09 From: ELizabeth CIty, NC Member No.: 10,929 Region Association: MidAtlantic Region |
This one has me stumped. The engine stalls momentarily on take off just after releasing the clutch and giving it throttle. I have replaced the centrifigul/points distributer with a vacum advance/electronic ign. I replaced the old 32/36 carb with a brand new 32/36 weber, and adjusted the timing to 27 and 34 deg. BTDC and back again; still, it stalls; has anyone ever seen this before with a carb conversion? Recent suggestions are: weak coil, carb facing the wrong direction, low idle jet too small. I am sure there are no vacuum leaks. The car had this set up when I got it 10 years ago and I am the first one to start the car in 20 years. The previouse owner said it ran fine back then.
BarberDave |
Nov 2 2009, 04:54 AM
Barberdave Group: Members Posts: 1,605 Joined: 12-January 03 From: Wauseon Ohio Member No.: 135 Region Association: Upper MidWest |
THat is the nature of the beast!!! Center carbs with long intake runners have a problem keeping the fuel from puddling in those long intake runners,untill hot. Get use to it. Or get 40IDF's !!!! Dave (IMG:style_emoticons/default/slap.gif) |
Lo-Fi Version | Time is now: 23rd May 2024 - 12:40 PM |
