Upping the wattage of the driving lights, Will the stock wiring/relays handle it?? |
aircooledtechguy |
Nov 4 2009, 04:57 PM
The Aircooledtech Guy Group: Members Posts: 1,966 Joined: 8-November 08 From: Anacortes, WA Member No.: 9,730 Region Association: Pacific Northwest |
I would like to add 100W H-3 bulbs to my stock driving lights on my '75. That's a 45W increase. Will the stock wiring handle it or am I in for a disappointment?? What upgrades should I do to pull this off?? Don't want to damage my ride. . . Thanks.
underthetire |
Nov 4 2009, 05:07 PM
914 Guru Group: Members Posts: 5,062 Joined: 7-October 08 From: Brentwood Member No.: 9,623 Region Association: Northern California |
I would like to add 100W H-3 bulbs to my stock driving lights on my '75. That's a 45W increase. Will the stock wiring handle it or am I in for a disappointment?? What upgrades should I do to pull this off?? Don't want to damage my ride. . . Thanks. I assume you have the originals not not backdated. 2 100 watt bulbs will draw about 17 amps. I think some wiring changes will be required imo. Just get some good aftermarket replacements with 55 watt. You sure you have 55 watt now? Halogens and that high of wattage were really not around so much in the 70's. |
underthetire |
Nov 4 2009, 05:11 PM
Oh, and if those later style ones are plastic by chance you will melt them.
aircooledtechguy |
Nov 4 2009, 05:29 PM
You sure you have 55 watt now? Halogens and that high of wattage were really not around so much in the 70's. Thanks for the info. Yes, they are 55W (1 - Jahn and 1 - Osram) I verified so I would know where I stood. I may look into some SilverStar 55W bulbs or similar. Does anyone have a bulb that they recommend for an upgrade?? |
VaccaRabite |
Nov 4 2009, 05:31 PM
En Garde! Group: Admin Posts: 13,446 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
Many 100w kits come with a relay. You should use it.
VaccaRabite |
Nov 4 2009, 05:32 PM
Why don't you do the 55watt H4 upgrade? You can get it from Pelican, and it is a BIG difference from stock.
Zach |
underthetire |
Nov 4 2009, 05:37 PM
Just remember to not touch the bulb !!!
detoxcowboy |
Nov 4 2009, 06:22 PM
Senior Member Group: Members Posts: 1,294 Joined: 30-January 08 Member No.: 8,642 Region Association: Africa |
I used 85 watt h3 PIAA crystal ion yellow in my pilots without relay or any special wiring, no problems. Longest I ever had them on was an hour plus... AT 100 watts your on the edge and heat can be an issue too, I would not worry about the lenses if it is glass but behing the fogs there are wires for the fogs themselves and horns. 100watt relay is about $6 vs your system and peace of mind.. Anything over 100 watt and your asking for it without precautions.. I would go relay if I were you and wrap your leads.. When you really need to use them and not just playing with your car, you can't afford not see when you need to see...
I lived on Anacortes misty overcast dewy foggy rainy, do it right or even tone it down a bit, sometimes to much light especially white just makes it worse much worse, I lived in Colorado snow all day snow all night and if your lights are really white and high beaming you can't see sqwaut just a white wall, to much reflection.. |
underthetire |
Nov 4 2009, 06:29 PM
QUOTE I lived on Anacortes misty overcast dewy foggy rainy, do it right or even tone it down a bit, sometimes to much light especially white just makes it worse much worse, I lived in Colorado snow all day snow all night and if your lights are really white and high beaming you can't see sqwaut just a white wall, to much reflection.. (IMG:style_emoticons/default/agree.gif) Tully fog by me. Sucks bulbs ! |
Lo-Fi Version | Time is now: 23rd May 2024 - 04:33 AM |
