flipb |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,729 Joined: 2-September 09 From: Fairfax, VA Member No.: 10,752 Region Association: MidAtlantic Region ![]() ![]() |
Lay it out there. What are you running? Any plans to change?
(If you have multiple teeners, answer about the 4-cyl that comes closest to being a daily driver. If your teener's on jackstands, answer about how it was and how it will be when you get it running again.) |
VaccaRabite |
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,465 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region ![]() |
I currently ave dual IDF 44s, and I am going to swap to dual IDF 40s.
Zach |
underthetire |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,062 Joined: 7-October 08 From: Brentwood Member No.: 9,623 Region Association: Northern California ![]() |
I'm using megasquirt. That will go with my rotary conversion if I ever do it.
tradisrad |
Senior Member ![]() ![]() ![]() Group: Members Posts: 985 Joined: 11-September 06 From: San Mateo, CA Member No.: 6,815 Region Association: Northern California ![]() |
Factory FI on a 2056 with Raby 9550 cam. MPS was tuned to match the cam. Runs great, drove it to work today!
tat2dphreak |
stoya, stoya, stoya ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 8,797 Joined: 6-June 03 From: Wylie, TX Member No.: 792 Region Association: Southwest Region ![]() ![]() |
dual weber 40s. but one day when I'm rich and smart I'll do a sweet aftermarket FI with crank-fire distributor-less ignition (IMG:style_emoticons/default/smile.gif)
gopack |
CHEESEHEAD in CA, MARK ![]() ![]() ![]() Group: Members Posts: 744 Joined: 7-August 04 From: Folsom, CA Member No.: 2,472 Region Association: Northern California ![]() |
I have dual Dellorto 36s. I have followed some sweet builds using ITBs and aftermarket fuel injection, and i lust after them. Maybe someday, AFTER i get the car on the road for a year or two, i will go down that road!
flipb |
I love these polls. Always some surprises. In the 914 ownership poll, I was surprised that having only one 914 puts me in the minority! On this poll, I was expecting to see at least a few folks considering a switch back to FI.
As for me... some PO put a Weber Progressive on it. I'm waiting for Raby's new cable linkage to come out and will hopefully buy a dual 40mm HPMX set from his shop. |
tat2dphreak |
I love these polls. Always some surprises. In the 914 ownership poll, I was surprised that having only one 914 puts me in the minority! On this poll, I was expecting to see at least a few folks considering a switch back to FI. As for me... some PO put a Weber Progressive on it. I'm waiting for Raby's new cable linkage to come out and will hopefully buy a dual 40mm HPMX set from his shop. if my engine was stock it would be stock FI... the stock FI is the BEST thing for a STOCK engine. the stock FI sucks for a non-stock engine. |
johnnie5 |
914 lover ![]() ![]() Group: Members Posts: 375 Joined: 14-October 08 From: San Diego, CA Member No.: 9,644 Region Association: Southern California ![]() |
Dual 40 Webers on a McMark 2056 with a Mallory and an MSD. Curious to see Jake's linkage as well. Running CB hexbar, hasn't failed so far....
Car is running pretty darn good, no plans to change... unless I win the lottery! |
zymurgist |
"Ace" Mechanic ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,411 Joined: 9-June 05 From: Hagerstown, MD Member No.: 4,238 Region Association: None ![]() |
Babydoll has stock D-Jet. Motor has Euro P&Cs but is otherwise stock. I plan to keep it that way (with the concurrence of her owner).
Mark Henry |
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada ![]() |
SDS crank fire FI and I have a huge 2.7/4 almost ready, but all plans have changed and the big 4 is moving over to the bug and the teen is getting a /6.
JmuRiz |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,434 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region ![]() ![]() |
dual weber 40s. but one day when I'm rich and smart I'll do a sweet aftermarket FI with crank-fire distributor-less ignition (IMG:style_emoticons/default/smile.gif) (IMG:style_emoticons/default/beer.gif) What he said |
johnnie5 |
the big 4 is moving over and the teen is getting a /6. (IMG:style_emoticons/default/drooley.gif) C'mon lotto! |
blitZ |
Beer please... ![]() ![]() ![]() ![]() Group: Members Posts: 2,223 Joined: 31-August 05 From: Lawrenceville, GA Member No.: 4,719 Region Association: South East States ![]() |
tradisrad |
Factory FI on a 2056 with Raby 9550 cam. MPS was tuned to match the cam. Runs great, drove it to work today! Same here, however, I would like to switch to an aftermarket setup eventually. The cars I have seen with modern efi start and run so much smoother. Is it possbile to gain more power out of our setup using aftermarket FI? What sort of gain coulsd be expected. Mine runs good, but I think the induction is the limiting factor? |
fiid |
Turbo Megasquirted Subaru Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,827 Joined: 7-April 03 From: San Francisco, CA Member No.: 530 Region Association: Northern California ![]() |
There's no option for "planning to add an intercooler". (IMG:style_emoticons/default/biggrin.gif)
underthetire |
Factory FI on a 2056 with Raby 9550 cam. MPS was tuned to match the cam. Runs great, drove it to work today! Same here, however, I would like to switch to an aftermarket setup eventually. The cars I have seen with modern efi start and run so much smoother. Is it possbile to gain more power out of our setup using aftermarket FI? What sort of gain coulsd be expected. Mine runs good, but I think the induction is the limiting factor? Bigger throttle bodies, idle circuit control, timing advance curves, new style injectors. Just depends on how far you want to go. Could be a BIG increase, could be minimal. |
r_towle |
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,591 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
Stock FI switching to Dual webers...just cause they sound so cool.
Different motor goes with the carbs so dont start whining...I know, I know, and I factored that in. Rich |
jsayre914 |
Speed Up !!! ![]() ![]() ![]() ![]() Group: Members Posts: 3,188 Joined: 10-February 08 From: Timonium MD 21093 Member No.: 8,696 Region Association: MidAtlantic Region ![]() |
im runnin stock d-jet on my 2.0 and love it
i got stock l-jet on my 1.8 love it too but i can only fit one engine at a time in there (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/biggrin.gif) |
Shade Tree |
Member ![]() ![]() Group: Members Posts: 260 Joined: 18-December 08 From: Springfield, Oregon Member No.: 9,860 Region Association: Pacific Northwest ![]() |
I've decided to put the webers on my Samurai so the 914 is going to stay with the dual Dellorto DRLA 40's
Lo-Fi Version | Time is now: 10th June 2024 - 04:11 PM |
