Ground Point Options? |
tornik550 |
Nov 26 2009, 10:19 AM
Senior Member Group: Members Posts: 1,248 Joined: 29-January 07 From: Ohio Member No.: 7,486 Region Association: None |
I have a MSD ignition and a few other electrical items mounted in the trunk. I have had many issues in the past with substandard grounding with my car. So now I am looking for a good grounding point for these items- preferably in the trunk. Previously, I had all of these items grounded to the engine case. I would prefer not to do this- mainly for cosmetic reasons.
Does anybody have any experience with drilling a hole in the trunk, placing a bolt through and using this as a ground (or something similar)? Not sure how well this would work but it would be convenient. My other option is to run the wires down to where the transmission ground strap connects to the body. I would prefer not to do this. Thanks, Steve (IMG:style_emoticons/default/beer.gif) |
ahdoman |
Nov 26 2009, 10:44 AM
It's phonetic...Ah-D-O-Man (Audioman) Group: Members Posts: 667 Joined: 7-November 05 From: Santa Clarita, Ca. Member No.: 5,084 Region Association: Southern California |
The trunk should be fine since it's grounded to the tranny. Just make sure to clean all the paint off the grounding surface and clean your connectors if you are reusing old ones.
McMark |
Nov 26 2009, 12:55 PM
To ground the MSD, you can use one of the fasteners that hold the MSD to the trunk. Any chassis metal should be good ground.
underthetire |
Nov 26 2009, 01:06 PM
914 Guru Group: Members Posts: 5,062 Joined: 7-October 08 From: Brentwood Member No.: 9,623 Region Association: Northern California |
You can alsose the external star lock washers to help. They bite in just a little. My battery is grounded in the trunk with no real problems.
ME733 |
Nov 27 2009, 07:16 AM
Senior Member Group: Members Posts: 842 Joined: 25-June 08 From: Atlanta Ga. Member No.: 9,209 Region Association: South East States |
(IMG:style_emoticons/default/popcorn[1].gif) ...A good ground to the engine block , to me, has always been a very good idea. the ground will ensure that your spark plugs, and (whatever) spark system will function as efficiently as possable. The pitfalls of everything else includes oily connections from the transmission to engine etc etc...use a crankcase through-bolt at the rear of the engine, or bottom of the engine. having TWO grounds never hurts eighter. Just peridocally check and clean........for your consideration. (IMG:style_emoticons/default/popcorn[1].gif)
r_towle |
Nov 27 2009, 09:30 AM
Custom Member Group: Members Posts: 24,591 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Use a nice grommet and drill a hole into the engine bay.
Ground it to the battery. Rich |
tornik550 |
Nov 27 2009, 09:31 AM
I forgot to mention one other part- my battery is in the front trunk.
McMark |
Nov 27 2009, 05:22 PM
Doesn't matter where your battery is. The chassis metal is good ground as long as your negative battery cable is connected well.
tornik550 |
Nov 27 2009, 06:29 PM
I thought that what he meant was that I should run a line directly to the battery in the engine bay which would be a pain with my setup since the battery is up front.
I did drill a hole in trunk and placed a small bolt through the hole. I sanded the body around the hole to ensure a good connection. Everything seems to work just fine. Thanks for everyones help. |
Lo-Fi Version | Time is now: 11th June 2024 - 10:54 PM |
