Front fender removal, How do I remove without destroying |
okkie |
Nov 26 2009, 01:21 PM
Newbie Group: Members Posts: 20 Joined: 16-November 09 From: South Africa Member No.: 11,046 Region Association: None |
Has anyone on the board removed their 914's fenders without destroying them? What is the procedure and possible pitfalls I need to watch for? We don't have parts cars all over the country here, so they are valuable to us.
Okkie |
jmill |
Nov 26 2009, 01:33 PM
Green Hornet Group: Members Posts: 2,449 Joined: 9-May 08 From: Racine, Wisconsin Member No.: 9,038 Region Association: Upper MidWest |
You have to drill out the spot welds, split the seam and do some cutting. There is no easy way. If your cutting a parts car you'll want to cut more than you would need for a repair. Here's a picture of my front passenger fender drilled out at the spot welds and cut near the cowl.
If your chopping up a parts car you might want to quarter the car up to be sure you have everything you would need for a repair on any corner of the car. Attached image(s) |
r_towle |
Nov 26 2009, 06:20 PM
Custom Member Group: Members Posts: 24,591 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
remove the undercoating near the passenger compartment and you will see the other seams that need to be removed.
there is a simple flange that holds the fender vertically...just cut that flange off the car. Then you can drill the spot welds out once it is off the car, and weld a new L shaped flange back on the inner fender. Clean all the undercoating and seam sealer out....you will see what holds it....its not that hard. RIch |
Lo-Fi Version | Time is now: 12th June 2024 - 09:05 AM |
