> Going to bring the car to the shop, I need some help
weird_looking_cactus
post Mar 19 2004, 04:05 PM
Cactus
Im getting very tired of trying to fix my car my self so I guess Im going to fork out the money and just pay someone to get it running for me. I can get it started by pouring a little bit of gas right into the throttle body but the car won't stay started. I had the car running on 2 pistions not to long ago and I have just replaced a fuel injecter after testing it and finding out it does not work. I have already put new spark plugs changed the oil and replaced the fuel lines but now it just won't stay going. If I press on the gas, once I get it to start it will ether die cause it gets fluided or it will jump up to a high rmp then drop like a door knob. The only place I can find that will work on my car is charging $70 a hour so what do I tell him to fix? Is it my timing or somthing else. My car is a 2.0 1975. Thanks
Replies(1 - 19)
TheCabinetmaker
post Mar 19 2004, 04:13 PM
I drive my car everyday
Sounds like a fuel delivery problem. If it starts, the timing is probably close. Can you hear the fuel pump running for just a few seconds? If you take it to an experienced 914 guy, he should be able to diagnose the prob in an hour or so, and give you a price on repair. Have you bought that Haynes manual yet? Ya got to have some reading material of some sort or ya just ain't gonna be happy.
post Mar 19 2004, 04:21 PM
Cactus
Yep I have a manuel the place Im bringing to is a forgin auto place I see lots of VW bettles outside so I hope they are experienced. Once the car is started I hear the fuel pump going.
John2kx
post Mar 19 2004, 04:30 PM
Weird,
If you have given your best shot at getting car to run without positive results, I would give a pro a try. Give them a cap on what your willing to spend $$$$ wise, but from what I have experienced in the past, a good mechanic should have things figured out in less than a hour or two. To save time and money, you should attempt to find someone with 914 experience.
You may be in for less than $5.00 in parts and his time or need more expensive fuel injection parts. It's going to take a little time to figure it out........yours or his.
John
post Mar 19 2004, 04:51 PM
Cactus
Well great I think I found my problem is I need a new flue injecter computer. Not even my new fuel injecter I just stuck in is working. I can see were it runs into the relay and everything checks out good there. But just the other day I had my injecters squirting. How long does the engine have to run before they start to work.
lagunero
post Mar 19 2004, 04:58 PM
Donkey Member
Great that you may have found the problem but at this point take it to the shop. They'll repair that and diagnose all the other doubts you may have. After it's running smooth and you're not so frustrated you can get back tinkering with it (IMG:style_emoticons/default/wink.gif)
TheCabinetmaker
post Mar 19 2004, 05:09 PM
Cactus, all of sudden this sounds like the fuel injection points. They are in the bottom of the dizzy, and connect to the system via a plugin on the front side of the diz. Make sure this connector is pluged in good and its clean. Read you manual on how to remove the FI trigger points and make sure they are clean, and the little braided wire is not broken. This is what tells the injectors to fire. There are two contacts. Each one controls two injectors. When the contact closes(or opens, can't remember) it tells two injectors to open and have fuel in the intake waiting for the valve to open, and the plug to fire. Running on two clyinders is a good indication of this problem. You'll have to pull the diz. You already know how to do that, right?
Good Luck
post Mar 19 2004, 05:10 PM
Cactus
Well now I know what the problem is I would like to try and fix the car my self to save some money. I have no clue what you are talking about when you say dizzy. And I also don't know what you mean when you say pull the diz. Im sorry. (IMG:style_emoticons/default/huh.gif) Im looking in my manuel right now can't find anything on the fuel injection triggers. Can you give me a page number. Thanks
lapuwali
post Mar 19 2004, 05:21 PM
Not another one!
They have to be working from the first turn of the key, or the car won't start. Can't run without fuel, and the only source of fuel is the injectors.
Test your fuel pump. Disconnect the fuel line to the fuel pressure regulator, point it at a bucket , and turn on the key. If no fuel comes out, either the pump is dead, the wiring to it is bad, or there's a blockage. Or you don't have any fuel in the tank...
There's a great book on troubleshooting and repairing all Bosch fuel injection systems by Charles Probst. It covers all of the various injection systems used on 914s, and has step-by-step instructions on how to solve just about every typical problem. The book will cost much less than one hour of a mechanic's time.
It's actually quite unlikely to be the ECU. Test the simple stuff first.
lapuwali
post Mar 19 2004, 05:22 PM
Not another one!
Diz = Dizzy = Distributor, which you've already shown you're quite familiar with. :-)
post Mar 19 2004, 05:25 PM
Cactus
Ah thats what you mean about dizzy thanks on the fuel injection points I think I figured that out is it the control unit adjustment points that is right on the computer. If so Im going to go mess around with that right now.
TheCabinetmaker
post Mar 19 2004, 05:26 PM
Ecu's almost never go out. What manual do you have? We can try to point you to the right page. Yes, I thought you already knew about the diz(distributor). (IMG:style_emoticons/default/wacko.gif)
post Mar 19 2004, 05:46 PM
Cactus
I have the haynes manuel I think I found what were talking about its just a plug that has 3 wires in it. hooked into the dizzy (IMG:style_emoticons/default/mueba.gif)
TheCabinetmaker
post Mar 19 2004, 05:48 PM
was it plugged in?
JeffBowlsby
post Mar 19 2004, 05:52 PM
Another thing that will prevent the fuel injectors from firing is if the 3 ground connection (6 wires) at the rear center of the engine case (on top), coming off the FI harness are not making good electrical contact or have come loose.
post Mar 19 2004, 06:16 PM
Cactus
Well this is the best thing to happen to me so far. I went to another auto repair shop and I started to talk about with one of the guys working and he says he knows VW egines inside and out. He pointed to his own super bettle that he stuck twin carburators on. He said to bring it in tomarrow and he will take a look at it and said if it can't fix it he will through some double carburators on for $500-$600 he said he also works on many 914's. As soon as he said double carburater my eyes lit up. Im so happy to find someone who knows what they are doing and Im probly going to go with the carburaters so I can make my engine look cool and easy to work on. Im not going to have to worry about all these wires. Thanks for all the help you guys have givin me so far.
lapuwali
post Mar 19 2004, 06:33 PM
Not another one!
No, now you'll just have to worry about a lot of little brass parts with tiny holes that get clogged easily. You'll have to put up with not having any kind of cold-start circuit (IDFs fitted to VW engines have no choke circuit), which can be a problem in a cold climate. And I have dual carbs on my car, so I'm hardly biased against them.
The D-Jet system, when working, works well on a stock or near stock engine. Really, buy a copy of Probst's book ($30, not $600), and you'll have the stock EFI system running quickly. Just as soon as I can get to it, I'm converting my car FROM carbs to EFI, simply because it makes it better day-to-day.
TheCabinetmaker
post Mar 19 2004, 06:35 PM
opps, another one lost to the dark side (IMG:style_emoticons/default/ohmy.gif) Too bad.
nebreitling
post Mar 19 2004, 06:39 PM
Member Emeritus
i have to disagree on this one. even though carbs won't give you the power, smoothness, or reliability that a working Djet has (on a stock motor), that approach is probably your best bet if you're tired with fiddlling with it or are a bit in over your head. be aware, however, that you (or your mechanic) will still need to sort out any ignition problems. nevertheless, i'd just like to hear that you're driving the thing.
shell out the dough and enjoy your porsche.
n
GWN7
post Mar 19 2004, 06:55 PM
King of Road Trips
Haynes manual -chapter 3/ Ignition system, page 66 has a diagram of the dizzy ...part #36 "Releasing contacts for fuel injection system" is what your looking for.
As it was posted earlier they triger two of the injectors each. Pull all your injectors and see which aren't squirting. I can't remember which does which, but someone here will.
Check the cheap simple things before handing your cash off to someone else.
- Lo-Fi Version Time is now: 11th July 2025 - 03:46 AM
