wayne1234 |
Member ![]() ![]() Group: Members Posts: 260 Joined: 6-April 09 From: indianapolis in Member No.: 10,238 Region Association: None ![]() |
Well most know I have been doing alot of rust repair, and I have gotten near the end. The hell hole has been replaced and motor mount. and long material behind the motor mount... I used weldable primer on the back side of the metal. But I'm guessing that after welding there has to be some burn off. leaving some unavoidable exposed areas inside the longs.. some one had mentioned this in my rebuild thread.. and It got me thinking. What would be suggested to treat or coat the inside of the longs, then maybe paint them? I'm picturing a long wand like maybe a Ziebart rust proofer would maybe use? make a acess hole in the front of the long and spray around in there and around the heating tube as well? could you use phosphoric acid wash first then rinse then maybe a heavy rustoleum coat? the excess would come out the drip holes? looking for ideas. Thanks for all you input
Joe Owensby |
JoeO ![]() ![]() ![]() Group: Members Posts: 527 Joined: 7-January 06 From: Spartanburg, SC Member No.: 5,385 Region Association: South East States ![]() |
As I repaired mine, I tried to use the zinc primer on all inside surfaces. After all was completed, I bought some stuff from Eastwood that is made for this purpose. It came with a long hose and wand. I removed the cover on the inside of the long for access to the back portions of the inner long. I then used the Eastwood spray to coat the inside of the long. The oval cutout near the inside seat location would give access to the rear and centre of the long. I used a flexible 3/8 hose with the nozzle attached to snake up and through the long, forward and backward. the nozzle had a spay opening that sprayed out to the side. Rotating the hose, rotated the spray pattern. I accessed the front portion of the long via a hole inside the car near the door jamb. I sprayed a lot of the stuff, but made sure that the drain holes are not blocked. JoeO
veltror |
Senior Member ![]() ![]() ![]() Group: Members Posts: 930 Joined: 27-April 08 From: Potters Bar Herts UK Member No.: 8,978 Region Association: None ![]() |
I am going to use a Dinitrol kit
FourBlades |
From Wreck to Rockin ![]() ![]() ![]() ![]() Group: Members Posts: 2,056 Joined: 3-December 07 From: Brevard, FL Member No.: 8,414 Region Association: South East States ![]() ![]() |
You are supposed to rinse phosphoric acid washes with lots of water when done to remove the acid. This would either be hard inside your longs or result in lots of moisture being trapped in there. I would avoid it and just use a product made for spraying inside car cavities. I sprayed a bunch of cold galvanizing paint into mine to hopefully slow the corrosion process. That stuff works great on the steel parts of my boat trailer that get dipped in sea water regularly and left outside all the time. John |
wayne1234 |
four blades, do you use the cold galv paint like Rustoleum? would I need any prep? or just flood the hell out of it? Alos any body know what eastwood product was mentioned earlier I just spent about hour looking for it on their site I must be blind, but found some other stuff that was interesting
Katmanken |
You haven't seen me if anybody asks... ![]() ![]() ![]() ![]() Group: Members Posts: 4,738 Joined: 14-June 03 From: USA Member No.: 819 Region Association: Upper MidWest ![]() |
I'm jelous Veltror...
That Dinitrol cavity wax got an amazing rating in one of my old english car mags. They painted a bunch of metal plates with different rustproofig compounds on half of the plate, scratched the rustproofing with a nail, and then sprayed them with salt water for about 6 months.... The Dinitrol cavity waxes came out the best and seemed to preserve the steel on both sides.... Hmmmmmmm (IMG:style_emoticons/default/idea.gif) (IMG:style_emoticons/default/idea.gif) (IMG:style_emoticons/default/idea.gif) Mebbe you could become the go to guy for decent rustproofing materials... Over here, rustproofing is non-existant except for a few expen$ive shops..... |
IronHillRestorations |
I. I. R. C. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,825 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None ![]() ![]() |
cal44 |
Member ![]() ![]() Group: Members Posts: 165 Joined: 8-October 09 From: Encinitas, Ca. Member No.: 10,910 Region Association: Southwest Region ![]() ![]() |
If I may. Using the wax products are fine IF ALL of the moisture is gone on the metal, likewise with paint. I use basic Por-15 paint, it cures with moisture and will adhere to rusty metal. Idealy one could have a way of moving the car upside down and on its sides to spread the poured material around inside the longs but some of are us are hurting for room.
Katmanken |
I bought a rusproofing wand kit from JC Whitney years ago. Came with a variety of wands to use with an air compresor, a set of hole plugs to seal the spray holes, and 4 quarts of black rustproofing material. After reading about the advantages of the tan cavity waxes like Dinotrol, that would be my choice to coat the inside of the longs.
Seach JC Whitney to see if they are still available or google rustproofig kit..... |
charliew |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,363 Joined: 31-July 07 From: Crawford, TX. Member No.: 7,958 ![]() |
If you ever put por15 over rust and it ever gets ANY moisture it is a place to rust worse than if it was open to the air. It will encourage rust through. I have found wax in cavities that has been there a long time and it is still working great. The thing is nothing washes it off because there is usually no direct pressure on it inside a cavity. Now when it is on the inside and the panel is welded to it is gone in that spot and the rust will start at the weld and go out and sometimes go under the wax. Using body plugs is better than not using wax.
Lo-Fi Version | Time is now: 6th July 2025 - 11:49 AM |
