| Strudelwagon |
Dec 12 2009, 05:24 PM
Member ![]() ![]() Group: Members Posts: 411 Joined: 11-October 08 From: interior, British Columbia Member No.: 9,633 Region Association: Canada |
Hi,
Well through a little investigation ,I have discovered that the PPPO had installed a 911 clutch pedal spindle and lever. Not only is the spindle an inch longer (he had spacers installed) but so is the lever at the cable/clevis end. This of course broke the clutch tube off the inner tunnel (which I have rewelded better that new)and with spacers removed now makes contact with the gas pedal linkage. This gives me a couple of options: order a new spindle/lever from pelican or just cut the 911 one down to size. Because I'm all about fixing what I have, I need the dimension from the center of the spindle to the center of the clevis hole. anyone have a pedal cluster in the tickle trunk that could take a measurement and help a member out? PS- this is not my cluster but shows the part I need to modify on mine Thanks Steve ![]() |
| Larry.Hubby |
Dec 12 2009, 06:09 PM
Member who doesn't post much, but has a long time in 914s ![]() ![]() Group: Members Posts: 191 Joined: 24-November 04 From: Palo Alto, CA Member No.: 3,172 Region Association: Northern California |
I measure 1.497" on a stock 914 clutch release lever.
| Strudelwagon |
Dec 12 2009, 06:14 PM
I measure 1.497" on a stock 914 clutch release lever. Thanks Larry, I knew you guys would come thru (IMG:style_emoticons/default/beer.gif) Steve |
Lo-Fi Version | Time is now: 16th April 2026 - 05:03 AM |
