Geezer914 |
Geezer914 ![]() ![]() ![]() ![]() Group: Members Posts: 2,003 Joined: 18-March 09 From: Salem, NJ Member No.: 10,179 Region Association: North East States ![]() ![]() |
Which prong does this yellow wire attatch to?
Geezer914 |
had to resize picture and edit post
ClayPerrine |
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,414 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille ![]() ![]() |
That is the wire that powers the fuel pump on a 1.8L L-Jet system. It needs to be hooked to one of the two rear most connectors on the 4 pin connector on the relay board.
Without that wire the fuel pump will never run when the engine is cranking, and that will keep the car from starting. |
jsayre914 |
Speed Up !!! ![]() ![]() ![]() ![]() Group: Members Posts: 3,210 Joined: 10-February 08 From: Timonium MD 21093 Member No.: 8,696 Region Association: MidAtlantic Region ![]() |
Attached image(s) ![]() |
ClayPerrine |
you don't need any of the relays in that relay board.... |
jsayre914 |
Then I have Spares (IMG:style_emoticons/default/biggrin.gif)
Geezer914 |
Thanks for the help.
Lo-Fi Version | Time is now: 1st July 2025 - 10:42 PM |
