kenshapiro2002 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,444 Joined: 23-July 09 From: Bawlmer, MD Member No.: 10,598 Region Association: MidAtlantic Region ![]() |
I'm going to eliminate the glove box and the radio. My first thought is to get a flat piece of thin steel (like Porsche used behind the center piece of the dash) that extends from the steering wheel all the way over to the right side where the face ends, and cover that entire piece with the basket weave vinyl. Is that a decent way to execute this? If so, is it correct that it will "sandwich" between the dash top and the knee cap piece, as well as being glued? If so, can i slide it under the dash top or does it need to be removed?
Spoke |
Jerry ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,187 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None ![]() ![]() |
With the bottom dash removed, these pieces are easily installed using double-sided tape to hold the metal to the dash. Not sure how to attach the metal plate over the radio and glovebox holes.
Why no glovebox? I would assume the radio will go somewhere else or replaced by an iPod. |
kenshapiro2002 |
Might eliminate the glovebox just for "cleanliness". I thought about an iPod, but might just go with no tunes...just the engine sounds. How does the ventilation control unit come out?
With the bottom dash removed, these pieces are easily installed using double-sided tape to hold the metal to the dash. Not sure how to attach the metal plate over the radio and glovebox holes. Why no glovebox? I would assume the radio will go somewhere else or replaced by an iPod. |
Jeffs9146 |
Ski Bum ![]() ![]() ![]() ![]() Group: Members Posts: 4,062 Joined: 10-January 03 From: Discovery Bay, Ca Member No.: 128 ![]() |
Since you are taking everything out, I would put a sub box up there!!! (IMG:style_emoticons/default/idea.gif)
kenshapiro2002 |
I might if I knew what that was.
Since you are taking everything out, I would put a sub box up there!!! (IMG:style_emoticons/default/idea.gif) |
SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,257 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
kenshapiro2002 |
kenshapiro2002 |
Just decided to leave it..makes life simpler, and I figure I need a place to throw tickets without them blowing away. The glove box itself is in pretty good shape other than a coupla holes in the rear on the bottom...forty years of abrasion I guess. Think I may just rough it up...clean it up, and fiberglass over the outside to reinforce it. Not sure what I'll do on the inside to clean it up...maybe glass over it as well, or "carpet" it with some kinda of felt.
tat2dphreak |
stoya, stoya, stoya ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 8,797 Joined: 6-June 03 From: Wylie, TX Member No.: 792 Region Association: Southwest Region ![]() ![]() |
trust me, leave the vent controls, to me they were a PITA to get out, and even worse to get back in (IMG:style_emoticons/default/smile.gif)
kenshapiro2002 |
They are surrounded by freakin' electrical tape on the face of the dash. I want to replace it with the basket weave vinyl. How do I get the metal piece out to cover it without removing the controls?
trust me, leave the vent controls, to me they were a PITA to get out, and even worse to get back in (IMG:style_emoticons/default/smile.gif) |
SirAndy |
How do I get the metal piece out to cover it without removing the controls? Short answer: You don't ... You need to loosen the controls (Remember that 10mm nut?) and slide the controls out. You can get it out far enough without removing the cables etc.. as they're a pain in the rectum to put back on there. The chrome strip is held in by 4 tabs that you have to press down and then carefully pry on the chrome to remove it. (IMG:style_emoticons/default/smash.gif) Andy |
kenshapiro2002 |
Gracias...tomorrow's job.
kenshapiro2002 |
Either different on a 1970, mine's missing, or I'm blind. Couldn't find any retaining nut at all. In fact, can't find any way the unit is held in place unless it's merely pressed in there and held in place by the dash itself. The chrome trim strip simply had four horizontal tabs that inserted into corresponding slots in the ventilation unit itself. Anyway...no problem getting it out. Just finished using the angle grinder with a wire wheel to clean up the dash and the metal plates that will get recovered. Out to buy trim adhesive and double sided tape. Damn I'm productive! Retirement rocks!
![]() How does the ventilation control unit come out? 10mm nut on the backside, slides out the front. Bunch-O-Wires-N-Cables attached to it as well ... |
SirAndy |
Either different on a 1970, mine's missing, or I'm blind. Couldn't find any retaining nut at all. In fact, can't find any way the unit is held in place unless it's merely pressed in there and held in place by the dash itself. Look harder ... (IMG:style_emoticons/default/rolleyes.gif) There's a tab on the backside that is bolted to a stud on the front firewall using a 10mm nut. (10mm being the wrench size, not the thread size) ... (IMG:style_emoticons/default/smash.gif) Andy |
kenshapiro2002 |
I see (said the blind man as he picked up his hammer and saw)...on the firewall...I was looking all over the dash back for it and just assumed... (IMG:style_emoticons/default/chair.gif)
kenshapiro2002 |
dlee6204 |
Howdy ![]() ![]() ![]() ![]() Group: Members Posts: 2,162 Joined: 30-April 06 From: Burnsville, NC Member No.: 5,956 ![]() |
Looks good! (IMG:style_emoticons/default/thumb3d.gif)
kenshapiro2002 |
Much better "live"...can never figure out what camera settings work best for a black interior under fluorescent lights...
Jeffs9146 |
QUOTE I might if I knew what that was. QUOTE(Jeffs9146 @ Dec 14 2009, 03:35 PM) Since you are taking everything out, I would put a sub box up there!!! Sorry it took me so long to reply, I have been out of town! A sub is a Subwoofer for a stereo if you decide to add one! |
kenshapiro2002 |
I'd like to be able to just hook an iPod up...no radio...no CD player. What do I need...just an amplifier?
Lo-Fi Version | Time is now: 11th July 2025 - 04:11 AM |
