Wanted: 1970 Steering Column, 12 Pin |
proto31 |
Dec 16 2009, 12:51 AM
Member Group: Members Posts: 413 Joined: 2-February 06 From: Costa Mesa, CA. Member No.: 5,515 Region Association: None |
I need a decent steering column from a 1970 4 cylinder, it needs to be a 12 pin type, apparently they went to a 14 pin in 1971. Let me know what you've got.
Thanks, Dan |
914Sixer |
Dec 16 2009, 01:32 PM
914 Guru Group: Members Posts: 8,903 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Dan,
Do you need just the plug? |
proto31 |
Dec 16 2009, 06:13 PM
914Sixer |
Dec 16 2009, 07:10 PM
Check over on thesamba.com. The column is the same a the 70 Beetle.
bdstone914 |
Dec 16 2009, 11:01 PM
bdstone914 Group: Members Posts: 4,536 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Dan, Do you need just the plug? Hey Mark, I need the entire steering column. The last thing I need to get my car started. Dan If they are the same as a VW Bettle there are many of them in local Pick a Part yards. Do you need the housing complete with turn signal switch? I think the 70 had the wiper switch on the dash, Right? Bruce |
proto31 |
Dec 17 2009, 10:45 AM
Dan [/quote] If they are the same as a VW Bettle there are many of them in local Pick a Part yards. Do you need the housing complete with turn signal switch? I think the 70 had the wiper switch on the dash, Right? Bruce [/quote] I need it complete with the housing and turn signal switch, the wiper switch was on the dash. I didn't think that the VW beetle column was the same, the 914 version had it's own 914 part number. |
914devotion |
Dec 17 2009, 11:20 PM
I'm new here ... Group: Retired Members Posts: 0 Joined: 17-December 09 From: los angeles Member No.: 11,139 Region Association: None |
[quote name='proto31' date='Dec 17 2009, 08:45 AM' post='1251868']
Dan [/quote] If they are the same as a VW Bettle there are many of them in local Pick a Part yards. Do you need the housing complete with turn signal switch? I think the 70 had the wiper switch on the dash, Right? Bruce [/quote] I need it complete with the housing and turn signal switch, the wiper switch was on the dash. I didn't think that the VW beetle column was the same, the 914 version had it's own 914 part number. [/quote] I have a wiper washer squirt switch that goes on the right side, and the turn signal switch that sits on the left side if you want. |
OU8AVW |
Dec 18 2009, 08:13 AM
Yacht Rigger Group: Members Posts: 1,803 Joined: 1-October 08 From: Granbury, TX Member No.: 9,601 Region Association: Southwest Region |
How about a Karmann Ghia unit. That's my plan on my 71. It's almost exactly the same. At least I can't tell any diff.....
914werke |
Dec 18 2009, 08:27 AM
"I got blisters on me fingers" Group: Members Posts: 10,140 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
Pm sent
914Sixer |
Dec 18 2009, 09:27 AM
My bad. It is the KG unit not the Beetle.
Lo-Fi Version | Time is now: 8th June 2024 - 02:51 PM |
