HID H4 - High / low Both HID New in box, $89 + shipping |
Mikey914 |
Dec 19 2009, 03:20 AM
The rubber man Group: Members Posts: 12,678 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
I bought pair of sample HID units for a possible group buy, but I wanted to install one and test it for awhile before offering these up.
I'm not currently driving my car, and it looked like it was going to require a full day to mount correctly. I don't have time to do this. You will need to be using H4 lenses that allow for the bulbs to be replaced. tis unit will draw less that the stock 55w, so no need for an upgraded harness, but you will need to tap into a positive to power ( as well as secure a ground) the high low controller. I had seen these going at in the $120 range and though this would be an excellent upgrade. I had the HID low/ halogen high on my 951, and really liked the HID, but thought the high was cheasy. These are HID for both. These are 9000k that have a slight blue tint. I bought 2 sets and I'm keeping one for myself, but thought someone else may want to try it out, as it's going to be awhile before I'll get to it. Attached thumbnail(s) |
Als914 |
Dec 19 2009, 12:13 PM
Lighting my way Group: Members Posts: 330 Joined: 1-January 06 From: Hemet,Ca. Member No.: 5,346 Region Association: Southern California |
Would you consider an upgrade to your dash gauges to LED strip lighting in trade? Check out what can be done in the Member Vendor Forum titled "LED Strip Lighting", You would probably get you $120 worth depending on what you would want done.
Best regards, Al |
wbonucci |
Dec 19 2009, 01:21 PM
Newbie Group: Members Posts: 6 Joined: 2-December 09 From: Pasadena, CA Member No.: 11,091 Region Association: Southern California |
i would go in for some brighter lights
Mikey914 |
Dec 19 2009, 05:16 PM
Would you consider an upgrade to your dash gauges to LED strip lighting in trade? Check out what can be done in the Member Vendor Forum titled "LED Strip Lighting", You would probably get you $120 worth depending on what you would want done. Best regards, Al Al, thanks for the offer, but I'vegot the BA7's in mine and I'm happy with them. I do appreciate the offer. |
Lo-Fi Version | Time is now: 8th June 2024 - 10:27 PM |
