luvatenor |
Newbie ![]() Group: Members Posts: 47 Joined: 20-December 09 From: NY Member No.: 11,154 Region Association: None ![]() |
Having found that my slopping shifting was due to an absence of the firewall bushing. I proceeded to attempt to install one. After 2 hours of frustration and pain, I abandoned my effort to fight another day. Does anyone have an easy way(or easier) to install this bushing? Any comments are greatly appreciated- Rolf
Geezer914 |
Geezer914 ![]() ![]() ![]() ![]() Group: Members Posts: 2,008 Joined: 18-March 09 From: Salem, NJ Member No.: 10,179 Region Association: North East States ![]() ![]() |
Place the bushing in a pot of boiling hot water. This will make the bushing pliable. Use a wide blade sdrew driver to give it some help. It will resume its original shape after it cools. You can't install it with the shift rod in place.
Sleepin |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,647 Joined: 20-November 07 From: Grand Junction, Co. Member No.: 8,357 Region Association: Rocky Mountains ![]() |
Place the bushing in a pot of boiling hot water. This will make the bushing pliable. Use a wide blade sdrew driver to give it some help. It will resume its original shape after it cools. You can't install it with the shift rod in place. (IMG:style_emoticons/default/agree.gif) Pretty simple if you follow those rules. Once it is soft I usually give it a slap with a rubber mallet...pops right in! |
luvatenor |
Place the bushing in a pot of boiling hot water. This will make the bushing pliable. Use a wide blade sdrew driver to give it some help. It will resume its original shape after it cools. You can't install it with the shift rod in place. (IMG:style_emoticons/default/agree.gif) Pretty simple if you follow those rules. Once it is soft I usually give it a slap with a rubber mallet...pops right in! Unreal- I never thought of that- you might have saved me from more pain- thanks again-Rolf |
luvatenor |
Place the bushing in a pot of boiling hot water. This will make the bushing pliable. Use a wide blade sdrew driver to give it some help. It will resume its original shape after it cools. You can't install it with the shift rod in place. (IMG:style_emoticons/default/agree.gif) Pretty simple if you follow those rules. Once it is soft I usually give it a slap with a rubber mallet...pops right in! Unreal- I never thought of that- you might have saved me from more pain- thanks again-Rolf- approx how long should I boil it?- I guess I should bring the pot out to the car- yes?-thanks again |
luvatenor |
Place the bushing in a pot of boiling hot water. This will make the bushing pliable. Use a wide blade sdrew driver to give it some help. It will resume its original shape after it cools. You can't install it with the shift rod in place. (IMG:style_emoticons/default/agree.gif) Pretty simple if you follow those rules. Once it is soft I usually give it a slap with a rubber mallet...pops right in! Unreal- I never thought of that- you might have saved me from more pain- thanks again-Rolf- approx how long should I boil it?- I guess I should bring the pot out to the car- yes?-thanks again I did remove the shift rod first! |
Cevan |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,079 Joined: 11-December 06 From: Western Massachusetts Member No.: 7,351 ![]() |
Until its al dente?
Geezer914 |
Place it in the boiling water and bring the pot out to the car. It will be soft enough to work with, but you have to act fast.
Cap'n Krusty |
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California ![]() |
Bring the pot out to the car? Dude! You'll NEVER get the job finished .................
On the serious side, it would have been a good thing had you asked forst, because you probably removed the shift rod at the base of the lever, and you've made yourself a bunch more work ............. The Cap'n |
Jerry75914 |
Member ![]() ![]() Group: Members Posts: 124 Joined: 13-October 08 From: Half Moon Bay, CA Member No.: 9,640 Region Association: Northern California ![]() |
wow, that is amazingly simple and effective! I wish I'd known before I did mine a ways back... (IMG:style_emoticons/default/headbang.gif)
wobbletop |
Member ![]() ![]() Group: Members Posts: 382 Joined: 8-December 06 From: Ontario, Canada Member No.: 7,335 Region Association: Canada ![]() |
I used a heat gun as well to warm up the general area as well... otherwise the bushing gets real cold, real quick.
luvatenor |
Bring the pot out to the car? Dude! You'll NEVER get the job finished ................. On the serious side, it would have been a good thing had you asked forst, because you probably removed the shift rod at the base of the lever, and you've made yourself a bunch more work ............. The Cap'n Yes Cap'n, I did remove the shift rod and placed it in the tunnel by the shifter. When I ordered the bushing from Pelican, this is what they told me to do. I didn't realize it would bring me more work than I needed- never did this before-a learning curve. Thanks again for your help-Rolf |
watsonrx13 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,735 Joined: 18-February 03 From: Plant City, FL Member No.: 312 Region Association: South East States ![]() |
Here's my write up, with a link to this site. If you're not aware, we have a 914 Info section (see top of this page) that has various tech articles that our members have written to help the newbies.
-- Rob |
tat2dphreak |
stoya, stoya, stoya ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 8,797 Joined: 6-June 03 From: Wylie, TX Member No.: 792 Region Association: Southwest Region ![]() ![]() |
I didn't get mine hot enough when I tried, but used a long bolt with a washer to act as a press to get it in... worked like a champ.
luvatenor |
I didn't get mine hot enough when I tried, but used a long bolt with a washer to act as a press to get it in... worked like a champ. I am amazed. I used the boiled water method- timed it and once under the car took me 10 seconds to get it in! Worked like a charm and i owe it all to you- Thank you again-Rolf |
Lo-Fi Version | Time is now: 6th July 2025 - 10:29 AM |
