| sixaddict |
Dec 21 2009, 10:26 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,058 Joined: 22-January 09 From: Panama City Beach, FL Member No.: 9,961 Region Association: South East States
Need black rivets for door thresholds plate. It is a conversion so
" absolutely correct" is not an issue but close would help. Tried search for vendors but don't know how to get there. Any guidance would be appreciated. THX TOT |
| johnnie5 |
Dec 21 2009, 10:29 AM
914 lover ![]() ![]() Group: Members Posts: 375 Joined: 14-October 08 From: San Diego, CA Member No.: 9,644 Region Association: Southern California |
Look up yello914 in member vendors. Raul, he is the guy who makes the aftermarket threshold sills and carpet rails. He should be able to get you some black plastic rivits.
| jonferns |
Dec 21 2009, 10:32 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,081 Joined: 29-March 07 From: New Jersey Member No.: 7,631 Region Association: North East States
| Socalandy |
Dec 21 2009, 10:45 AM
Its got to be Yellow!!! ![]() ![]() ![]() ![]() Group: Members Posts: 2,432 Joined: 29-August 09 From: Orange Member No.: 10,742 Region Association: Southern California |
If you have an ACE Hardware near you they have a great selection of Non feris fasteners.
| dr914@autoatlanta.com |
Dec 21 2009, 10:55 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,233 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
Need black rivets for door thresholds plate. It is a conversion so " absolutely correct" is not an issue but close would help. Tried search for vendors but don't know how to get there. Any guidance would be appreciated. THX TOT We have found that without enlarging the holes (we do not do that these days, used to use the black Wurth rivets and slightly enlarge the holes) the factory rivets are the only alternative. Todd's are slightly bigger (just like the Wurth ones) and need a leg broken off The factory are opaque, perfect for the 70-early 73 models, and for the 73 1/2-76 models we install them and then carefully touch them up with a magic marker. Fits correctly and looks correct |
| tod914 |
Dec 21 2009, 11:42 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,755 Joined: 19-January 03 From: Lincoln Park, NJ Member No.: 170 |
I'm getting low on the black, but have some if you need them. 20 cents each v $1.40 or so from Porsche. Once they run out, I'll see if the manufacturer will duplicate them to exact oem size. If you follow the instructions on the link, they go in easy. Let me know if I can help.
http://www.914world.com/bbs2/index.php?act...t=0#entry739856 |
| sixaddict |
Dec 21 2009, 02:15 PM
Thanks ALL !.......that should do it. TOT
Lo-Fi Version | Time is now: 15th April 2026 - 04:54 PM |
