Impeller bolt? |
Impeller bolt? |
jeffdon |
Dec 21 2009, 03:51 PM
Senior Member Group: Members Posts: 1,094 Joined: 24-October 06 From: oakland, ca Member No.: 7,087 Region Association: None |
OK, I was getting smug with myself for keeping such good track of all my parts. Now i cannot find the bolts that hold the impeller to the hub, not the bolt that holds the hub to the crank. Cannot even recall if there is a spacer that goes in the hub/crank bolt. Where can I find myself the proper parts?
SLITS |
Dec 21 2009, 04:13 PM
Any hardware store that sells metric fastners. Either flat headed or allen socket head as it depends on what your impeller looks like. If the impeller has a recess for the bolts use allen head.
or CV joint bolts And yes, the bolt that holds the hub to the crank has a washer. Make sure you check the length of the bolts for the impeller to the hub. You don't want them sticking out of the hub on the backside where they will dig into the case. |
Cap'n Krusty |
Dec 21 2009, 04:15 PM
Depending on which fan you have, there is a choice of 2 bolts. If the surface of the center area of the fan is flat, hex head bolts are used. If there are 3 counter sunk holes, then Allen head bolts are used. The length is CRITICAL; too short and you won't have enough thread engagement, too long and you'll eat the seal. The hub bolt has a flange under the head, and the surface of that flange has radial ribs cast in to help the bolt lock to the 6 (+/-) mm thick washer between the bolt head and the crankshaft. There is also a spacer between the fan and the hub. It is replaced with a pulley on cars with A/C. That spacer MUST be in there.
The Cap'n |
jeffdon |
Dec 22 2009, 03:14 PM
Depending on which fan you have, there is a choice of 2 bolts. If the surface of the center area of the fan is flat, hex head bolts are used. If there are 3 counter sunk holes, then Allen head bolts are used. The length is CRITICAL; too short and you won't have enough thread engagement, too long and you'll eat the seal. The hub bolt has a flange under the head, and the surface of that flange has radial ribs cast in to help the bolt lock to the 6 (+/-) mm thick washer between the bolt head and the crankshaft. There is also a spacer between the fan and the hub. It is replaced with a pulley on cars with A/C. That spacer MUST be in there. The Cap'n Still hunting for the center bolt. This the spacer that goes between the hub and fan??? And another between the hub and crank? |
Drums66 |
Dec 23 2009, 01:53 PM
914 Rudiments Group: Members Posts: 5,321 Joined: 15-January 03 From: Coronado,Cali Member No.: 151 Region Association: Southwest Region |
The keyway that slips into that notch in the hub
is missing?(not in the picture) (IMG:style_emoticons/default/idea.gif) |
Lo-Fi Version | Time is now: 2nd June 2024 - 03:09 PM |
