luvatenor |
Newbie ![]() Group: Members Posts: 47 Joined: 20-December 09 From: NY Member No.: 11,154 Region Association: None ![]() |
Another newbie question-In adjusting the shift rod, after installing new bushings, many people say to go to the transmission end and put the transmission in either 2nd or 3rd gear, before tightening the shift lever crimp bolt. How does one know where these gears are at the transmission? Everything looks the same when I move the lever.-Thanks Rolf
etcmss |
etcmss ![]() ![]() Group: Members Posts: 183 Joined: 20-April 06 From: Lancaster, Ky Member No.: 5,899 Region Association: Upper MidWest ![]() |
Another newbie question-In adjusting the shift rod, after installing new bushings, many people say to go to the transmission end and put the transmission in either 2nd or 3rd gear, before tightening the shift lever crimp bolt. How does one know where these gears are at the transmission? Everything looks the same when I move the lever.-Thanks Rolf Do you have the linkage installed? With the linkage installed---select 2nd or 3rd gear and adjust for vertical alignment of shifter and the clearance on each side is OK. Tighten the bolt on the shifter and then select 4th or 5th then reverse-1st----no impact to tunnel. If you go the search options at the top of the page----put in shift adjustment----you will find this subject-- I had this one a while back and it was shifter hitting the tuneel. |
Cevan |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,079 Joined: 11-December 06 From: Western Massachusetts Member No.: 7,351 ![]() |
I found it helpful to remove the rear tunnel access panel, grab a 13mm socket with extension and a pair of vice grips and go for a drive. Using the vicegrips to hold the rod rod in place thru the access panel, you can loosen the pinch bolt, adjust the shifter, tighten, and drive. Usually after 3-4 adjustments, I've got it perfect.
Gint |
Mike Ginter ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,098 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains ![]() ![]() |
Check out this thread. In particular, post #6
http://www.914world.com/bbs2/index.php?showtopic=80530& |
Lo-Fi Version | Time is now: 31st July 2025 - 05:00 PM |
