Front f/g bumper and spoiler w/ dzus fasteners, Any tips or pics on the best way to attach them? |
campbellcj |
Dec 24 2009, 05:53 PM
I can't Re Member Group: Members Posts: 4,547 Joined: 26-December 02 From: Agoura, CA Member No.: 21 Region Association: Southern California |
For no particular reason, other than slight weight savings, I want to re-do the way my front fiberglass bumper and spoiler (actually a couple different ones) are attached. Currently they are screwed/bolted on in a McGuyver'ed stock-like fashion. I have tons of dzus fastener parts and have used those for the rear bumper, targa top and so forth, so I figure I'll use them up front too.
Rather than re-invent the wheel, if anybody has advice or better yet - pics - on how to do this, it would be greatly appreciated! Thanks and Merry Christmas |
race914 |
Dec 27 2009, 06:07 PM
73 914-4 Group: Members Posts: 1,006 Joined: 31-October 05 From: Nipomo, California (Central Coast) Member No.: 5,027 Region Association: Central California |
Here's my front bumper dzus setup.
I used the stock bumper mounting holes, tapped some round stock and used some threaded rod to make the mounts adjustable. Welded a square plate to the end of the round stock for the dzus mounting. My camera is dying and the 2nd & 3rd pics aren't to clear, but I hope this helps give you an idea of one way to do it. |
race914 |
Dec 27 2009, 06:32 PM
Here's how I mounted the spoiler.
1st pic you can see a dzus fastener locations on each side of the oil cooler opening 2nd pic shows the dzus fasteners on the spoiler 3rd pic shows the location for the 2nd set of fasteners. On both sides, I have a dzus inside the front fender on the horizontal lip. green line indicates the location Both the bumper & spoiler setups have worked well. |
campbellcj |
Dec 28 2009, 01:26 AM
Thanks - that is very helpful !!!
blabla914 |
Dec 28 2009, 07:42 PM
I like primer Group: Members Posts: 321 Joined: 1-March 04 From: Connecticut Member No.: 1,740 Region Association: None |
Check the Turtlegirl build thread. Tabs were welded to the body. Less adjustable, but appeared pretty easy to get right.
Kelly |
sww914 |
Dec 29 2009, 11:02 PM
Advanced Member Group: Members Posts: 2,439 Joined: 4-June 06 Member No.: 6,146 Region Association: None |
Here's my front bumper dzus setup. I used the stock bumper mounting holes, tapped some round stock and used some threaded rod to make the mounts adjustable. Welded a square plate to the end of the round stock for the dzus mounting. My camera is dying and the 2nd & 3rd pics aren't to clear, but I hope this helps give you an idea of one way to do it. I was going to describe this setup. Glad you have pics! Hi Greg |
Lo-Fi Version | Time is now: 1st June 2024 - 05:29 PM |
