Roll Bar Vinyl, Technical Information Request |
John |
Mar 21 2004, 05:03 PM
member? what's a member? Group: Members Posts: 3,393 Joined: 30-January 04 From: Evansville, IN (SIRPCA) Member No.: 1,615 Region Association: None |
I am about to replace my roll bar vinyl on my street 914 and have a question about the proper glue to use. I am replacing the vinyl that I used 10 years ago (not the right material) because:
A.) It has air pockets under the vinyl B.) It is not the right material. The vinyl started to lift a long time ago and it was Ok, but I never really liked the way it looked on the car. I used that vinyl because 10 years ago I was cheap, poor and in college and spent my money on other things. I am now going back and re-doing some of the things that I did to cut costs when I repainted the car 10 years ago. I know there is no rust and that the paint is in good shape under the vinyl as I can see it and besides, I replaced them back when I repainted the car. My question is what would be the best glue to use? The material I am using now I believe is what I should have used. I purchased it from a vendor represented frequently on this board and it looks good. I am considering using 3M Super Trim Adhesive, but am not sure if I should be using this or if I should be using the 3M General Trim Adhesive. I am also going to replace the dash vinyl as well and what glue should I use for that? Any advice on this would be appreciated. Thanks, |
Ray Warren |
Mar 21 2004, 05:52 PM
Member Group: Benefactors Posts: 415 Joined: 1-October 03 From: Canada Member No.: 1,214 Region Association: None |
boxstr |
Mar 21 2004, 06:07 PM
MEMBER:PACIFIC NORTHWEST REGION Group: Members Posts: 7,522 Joined: 25-December 02 From: OREGON Member No.: 12 Region Association: Pacific Northwest |
With every set of CAMP 914 sail vinyl kits the installation instructions say to use 3M Super Trim Adhesive and be sure you have a clean area and READ INSTRUCTIONS.
CCLINCAMP914 |
Lo-Fi Version | Time is now: 17th June 2024 - 01:10 AM |
