Source for Damping Mat? |
D1A3 |
Dec 30 2009, 08:10 PM
Gruppe Neun Vierzehn Südosten Group: Members Posts: 362 Joined: 3-June 04 From: Atlanta, GA Member No.: 2,152 Region Association: South East States |
Does anyone know of a source (or have available) the "Damping Mat" for the rear trunk? You might know this part better as the black foam trunk pad that goes under the carpet. It's made of foam and has a vinyl cover. I need one for a 73-76 car.
I'm looking for part number 91455600310 and would like to find one intact, without tears, that is still supple. Most of the parts suppliers I have checked with don't have anything. THANKS! |
VaccaRabite |
Dec 31 2009, 07:33 AM
En Garde! Group: Admin Posts: 13,464 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
You are in Atlanta. Go drive over to AA, I bet they have one.
Zach |
dr914@autoatlanta.com |
Dec 31 2009, 08:58 AM
914 Guru Group: Members Posts: 7,888 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
70-72 a small yellowish thick foam pad available aftermarket and used
73-early 74 a full sized dark gray foam pad available used the last of the factory new ones not molded and cheap looking 74 1/2-76 a full sized black plastic covered light foam pad available aftermarket (Porsche changed the pad as not to absorb water) Does anyone know of a source (or have available) the "Damping Mat" for the rear trunk? You might know this part better as the black foam trunk pad that goes under the carpet. It's made of foam and has a vinyl cover. I need one for a 73-76 car. I'm looking for part number 91455600310 and would like to find one intact, without tears, that is still supple. Most of the parts suppliers I have checked with don't have anything. THANKS! |
D1A3 |
Dec 31 2009, 09:37 AM
70-72 a small yellowish thick foam pad available aftermarket and used 73-early 74 a full sized dark gray foam pad available used the last of the factory new ones not molded and cheap looking 74 1/2-76 a full sized black plastic covered light foam pad available aftermarket (Porsche changed the pad as not to absorb water) Does anyone know of a source (or have available) the "Damping Mat" for the rear trunk? You might know this part better as the black foam trunk pad that goes under the carpet. It's made of foam and has a vinyl cover. I need one for a 73-76 car. I'm looking for part number 91455600310 and would like to find one intact, without tears, that is still supple. Most of the parts suppliers I have checked with don't have anything. THANKS! Hi George, What is the correct part number in your catalog to search on for the late pad that came in the 76 cars? Thanks, Jason |
Dec 31 2009, 04:01 PM
914 556 003 10 that is the 74 1/2-76 part number
Lo-Fi Version | Time is now: 4th June 2024 - 11:51 AM |
