Is there a part number or source for the, alternator gasket (between the alternator and tin)??? |
jsayre914 |
Jan 2 2010, 07:24 PM
Speed Up !!! Group: Members Posts: 3,188 Joined: 10-February 08 From: Timonium MD 21093 Member No.: 8,696 Region Association: MidAtlantic Region |
I was in the middle of my alternator install when i noticed the gasket was missing between the unit and the tin. Instead there was a huge sloppy bead of clear silicon. I would like to purchase the rubber and put it back. anybody know where i can find this part??
jsayre914 |
Jan 2 2010, 07:40 PM
pic
Attached image(s) |
type47 |
Jan 2 2010, 08:21 PM
Viermeister Group: Members Posts: 4,254 Joined: 7-August 03 From: Vienna, VA Member No.: 994 Region Association: MidAtlantic Region |
I can't find anything in the PET, at least nothing in an illustration. The workshop manual calls it a "seal".
904svo |
Jan 2 2010, 09:34 PM
904SVO Group: Members Posts: 1,118 Joined: 17-November 05 From: Woodstock,Georgia Member No.: 5,146 |
try part number 022-903-203 got it from AA
McMark |
Jan 2 2010, 10:04 PM
Our classifieds should probably be able to hook you up.
914Sixer |
Jan 3 2010, 11:35 AM
914 Guru Group: Members Posts: 8,903 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
They are NLA from Porsche. I tried to get some two years ago. VW suppliers might have some though.
McMark |
Jan 3 2010, 12:47 PM
A similar piece was installed in T4 VW bus engines, but it's not the same. I'm not sure which the 912E one is.
detoxcowboy |
Jan 3 2010, 04:17 PM
Senior Member Group: Members Posts: 1,294 Joined: 30-January 08 Member No.: 8,642 Region Association: Africa |
(IMG:style_emoticons/default/drunk.gif) There is one on SambaVW.com under search for alternator.. Alot of VW and 914 use same Bosch alternator... And can interchange with most as well
jsayre914 |
Jan 3 2010, 06:20 PM
(IMG:style_emoticons/default/drunk.gif) There is one on SambaVW.com under search for alternator.. Alot of VW and 914 use same Bosch alternator... And can interchange with most as well Thanks Joe (IMG:style_emoticons/default/beerchug.gif) I just sent a message to the seller |
detoxcowboy |
Jan 3 2010, 06:24 PM
(IMG:style_emoticons/default/drunk.gif) There is one on SambaVW.com under search for alternator.. Alot of VW and 914 use same Bosch alternator... And can interchange with most as well Thanks Joe (IMG:style_emoticons/default/beerchug.gif) I just sent a message to the seller New boots with new clamps are available at airheadsvw.. nla most everywhere else.. $16 |
Lo-Fi Version | Time is now: 9th June 2024 - 10:39 AM |
