WTB, fuel pressure regulator and tank screen |
mtndawg |
Jan 5 2010, 11:36 PM
Member Group: Members Posts: 414 Joined: 26-January 09 From: Granite Bay, Ca Member No.: 9,985 Region Association: None |
I need these for a 1.7L d-jet. Please PM me if you have good ones. Shane
underthetire |
Jan 5 2010, 11:39 PM
914 Guru Group: Members Posts: 5,062 Joined: 7-October 08 From: Brentwood Member No.: 9,623 Region Association: Northern California |
I have a brand new tank screen. If your near Hayward, buggy house has them. If you want to buy mine, 8 bucks. Buggy house was 11. I ended up with 2, only need 1.
914Sixer |
Jan 6 2010, 08:43 AM
914 Guru Group: Members Posts: 8,903 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Go to Autohausaz.com for a new pressure regulator $38.
tod914 |
Jan 6 2010, 09:00 AM
Advanced Member Group: Members Posts: 3,755 Joined: 19-January 03 From: Lincoln Park, NJ Member No.: 170 |
Don't forget your 0-ring gasket you'll need for the filter sock when you change it.
mtndawg |
Jan 6 2010, 12:03 PM
I'll call Autohausaz.com today. Thanks tod914, where can I get the o-ring? What's the size? Do I need anything else to replace the sock?
underthetire |
Jan 6 2010, 12:17 PM
tod914 |
Jan 6 2010, 09:06 PM
PM your address and I'll send you out one. It should work fine for the sock. Just make sure you align it properly before you tighten it down. There is just enough for it to seal. There is alittle play so just be cognisant of that when you start to tighten it down. I got them at busdepot. Unfortunetly, only the smaller size ones are available there. Not sure what material it is, but it's not copper. The sock inserts in the tank, then the gasket, then the nut. You'll want the washer sealing to the nut. The sock has has a built in crush gasket. I'm not sure on the AA ones, only that the shipping will be more than the part lol.
Lo-Fi Version | Time is now: 8th June 2024 - 09:22 AM |
