Ceramic Coated Heat Exchangers, I just picked them up! |
Jeffs9146 |
Mar 22 2004, 06:45 PM
Ski Bum Group: Members Posts: 4,062 Joined: 10-January 03 From: Discovery Bay, Ca Member No.: 128 |
Way too cooL!!
Jeff Attached image(s) |
Jeffs9146 |
Mar 22 2004, 06:46 PM
darker one!
Attached image(s) |
jonwatts |
Mar 22 2004, 06:52 PM
no rules, just wrong Group: Benefactors Posts: 2,321 Joined: 13-January 03 From: San Jose, CA Member No.: 141 |
Interesting, they don't shine like other ceramic coated pieces I've seen. Who did the work?
PS - if it works who cares what it looks like |
Jeffs9146 |
Mar 22 2004, 06:55 PM
I chose the higher heat coating and decided to go flat because it will last longer!
If they were new HE's I would have gone gloss! Jeff |
anthony |
Mar 22 2004, 06:59 PM
2270 club Group: Benefactors Posts: 3,107 Joined: 1-February 03 From: SF Bay Area, CA Member No.: 218 |
Does the coating prevent them from rusting? How long should the coating last?
Jeffs9146 |
Mar 22 2004, 07:04 PM
QUOTE Does the coating prevent them from rusting? Yes! They are dipped and cleaned then coated inside and out. No more rust worries for quite a while. QUOTE How long should the coating last? That depends on how hard you use it! With the amount of driving I will be doing, they will last a life time! I don't know, I just wanted them to look better and last longer! Jeff |
415PB |
Mar 22 2004, 09:07 PM
Member Group: Benefactors Posts: 498 Joined: 7-August 03 From: So Cal Member No.: 996 |
They look great Jeff. I was thinking of picking up the Ceramic coating kit from Columbia Coatings to do my own stuff.
http://www.columbiacoatings.com/800fsgfdsg...6765ytrh567.htm |
Rgreen914 |
Mar 23 2004, 03:06 AM
Member Group: Members Posts: 285 Joined: 20-October 03 From: West Covina, Ca. Member No.: 1,266 |
I had an NOS set (1.7) of HE's done in the grey, though it appears to be a bit lighter. I then sent the Bursch exhaust and the rest of the heater ducting out to be coated; the heater stuff will be powder coated in a color close to that of the HE's.
I have had a set of JBA headers on my big block Suburban for about two years and the aluminum ceramic coating appears to be almost the same as the day I first installed them. I know that you can clean/shine the aluminum coating with Mother's wheel polish but I'm not about to remove the headers off my truck just to spruce them up a little; I have done it to headers that weren't on a car, though! |
Lo-Fi Version | Time is now: 9th June 2024 - 10:22 PM |
