| tornik550 |
Feb 7 2010, 02:01 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,248 Joined: 29-January 07 From: Ohio Member No.: 7,486 Region Association: None |
I am in the market for a new carb linkage. I currently have a hex bar linkage that has seen better days and needs to be replaced. I have dual weber 40 idf's. I have been looking around and haven't found many options. I do not have a lot of money to spend (another kid on the way and three Porsches in the garage).
What are my options for dual carb linkage. I can only spend up to about $150 however my wife would give me less problems if I spent more like $100. Where can I purchase linkages? I have only been able to find them at CB performance? |
| sean_v8_914 |
Feb 7 2010, 02:07 PM
Chingon 601 ![]() ![]() ![]() ![]() Group: Members Posts: 4,011 Joined: 1-February 05 From: San Diego Member No.: 3,541 |
Jake Raby sells a center pull linkage but your budget implies that you are in teh used linkage market where price dictates selection.
| tornik550 |
Feb 7 2010, 02:10 PM
| 7275914911 |
Feb 7 2010, 02:11 PM
Hummmm!!! ![]() ![]() ![]() Group: Members Posts: 757 Joined: 7-May 08 From: Mid-South Member No.: 9,028 Region Association: South East States
try CPI....they have a CSP bellcrank that is under 100 when I purchased last year. I believe it is smoother/better than hex bar. Raby is working on a cable linkage that looks like the best option out there??
Good Luck |
| sean_v8_914 |
Feb 7 2010, 02:27 PM
| sean_v8_914 |
Feb 7 2010, 02:34 PM
| tornik550 |
Feb 7 2010, 03:11 PM
Will this setup work with a 914 dual carbed engine? It appears to be made more for the type 1 engine or similar. Would it matter that the carbs are offset? The price is nice. It would love to get away from the crossbar. Also, I have jug spacers (engine is about 1 inch wider). Is there a way to compensate for this change with this type of linkage? Thank you to everybody for your help! Attached image(s)
| 7275914911 |
Feb 7 2010, 03:47 PM
Will this setup work with a 914 dual carbed engine? It appears to be made more for the type 1 engine or similar. Would it matter that the carbs are offset? The price is nice. It would love to get away from the crossbar. Also, I have jug spacers (engine is about 1 inch wider). Is there a way to compensate for this change with this type of linkage? Thank you to everybody for your help! Yes it works if base mounts to case at center case bolt properly...I ran that type before getting the CSP product I mentioned above. Then combined the two products together. I could not use the CSP base with my carb throttle pull locations. It is quite simple and I think it was smoother than a hexbar. A member here sold me one of those used for shipping only... |
| jmill |
Feb 7 2010, 03:56 PM
Green Hornet ![]() ![]() ![]() ![]() Group: Members Posts: 2,449 Joined: 9-May 08 From: Racine, Wisconsin Member No.: 9,038 Region Association: Upper MidWest |
Check this thread out: http://www.914world.com/bbs2/index.php?sho...&hl=linkage
| tornik550 |
Feb 7 2010, 06:41 PM
I am very interested in one of the CSP types. Does anybody have any pictures installed on a 914? I am curious about the throttle cable.
How does the one in the picture from above mount? Does it mount like the csp type pictured? Hard to tell from the picture. I am very grateful for everyones responses. Attached image(s)
| 7275914911 |
Feb 7 2010, 10:18 PM
I am very interested in one of the CSP types. Does anybody have any pictures installed on a 914? I am curious about the throttle cable. How does the one in the picture from above mount? Does it mount like the csp type pictured? Hard to tell from the picture. I am very grateful for everyones responses. The CSP mounts at back of engine case. The first one would mount in middle of engine case. The CSP needs throttle levers on the same side of carbs. At the rear. I am using base from first one and bellcrank/rods from CSP. I will try snd find a pic of mine. There was a good pic of the CSP mounted at rear in a thread here somewhere too. |
| craig downs |
Feb 7 2010, 10:58 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 770 Joined: 25-November 05 From: mira loma ca. Member No.: 5,189 Region Association: Southern California |
Thats a good linkage or you could wait a few months until Jake releases his cable linkage.
Lo-Fi Version | Time is now: 9th June 2026 - 11:55 PM |
