> Six Conversion Question, Ignition Setup
Ericv1
post Feb 8 2010, 12:47 PM
I have a 911 1970T as a donor car that the engine is coming from. Currentley, it's setup with a CDI (Captive Discharge Ignition). Will I need to move the Bosche CDI box over from the 911 inorder to get the engine running in the teener? Thanks in advance.
Replies(1 - 5)
dr914@autoatlanta.com
post Feb 8 2010, 12:58 PM
QUOTE(Ericv1 @ Feb 8 2010, 11:47 AM) *
yes
Ericv1
post Feb 8 2010, 01:27 PM
QUOTE(dr914@autoatlanta.com @ Feb 8 2010, 01:58 PM) *
yes
Thanks George.
post Feb 8 2010, 01:55 PM
And of course it mounts on a plate attached to the front of the battery tray.
QUOTE(Ericv1 @ Feb 8 2010, 12:27 PM) *
yes
Thanks George.
ClayPerrine
post Feb 8 2010, 02:20 PM
You will have to rearrange the wiring, as the CD box is not in the same relative location as it is on a 911. The engine harness is different too. I can provide a wiring diagram if you like, as I have done this on my car. I have the diagram on my computer at home, but not here.
I would suggest that you purchase a spare CD box and keep it with you. They are notorious about blowing the power transistor and leaving you stranded on the side of the road. I mounted mine on the back side of the factory bracket, and if the primary fails, I can just hook the wiring to the spare and continue down the road.
914Sixer
post Feb 9 2010, 03:21 PM
AA now has repro mounting brackets available now for a clean installation.
- Lo-Fi Version Time is now: 9th June 2026 - 11:55 PM
