Installed a front sway bar in my '75 today, Adjustable drop links... preload? |
johnnie5 |
Feb 11 2010, 10:02 PM
914 lover Group: Members Posts: 375 Joined: 14-October 08 From: San Diego, CA Member No.: 9,644 Region Association: Southern California |
Finally installed the sway bar today that has been sitting in my garage for a year or more. I set the adjustable heims the same distance as each other and bolted them into the u tabs.
Can someone please explain preload to me? Does it have to do with one drop link being longer than the other? |
Bruce Hinds |
Feb 11 2010, 10:42 PM
V-8 madness Group: Members Posts: 733 Joined: 27-December 06 From: Port Orchard, WA Member No.: 7,391 Region Association: Pacific Northwest |
Yes. If you drive the car often alone you may want to put one slightly longer than the other. Put your weight in the seat and check to see if one sides slightly higher than the other.
Any bushings in your Hiem joints? Without them you could eventually see some cracking around where the sway bar goes through the chassis. Might be fine for AX but for the street you need something to absorb the vibration. B |
McMark |
Feb 12 2010, 11:12 AM
Preload is....
If you remove the drop links all together, then lower the car, then measure between the a-arm and the sway bar ends you'll often find that each side measure differently. In order to remove all tension from the sway bar when unloaded, you may need different length (or better, adjustable) drop links to account for this difference. The bottom line is that you want the sway bar to be neutral until acted upon by outside forces. A preloaded bar is not neutral. |
SirAndy |
Feb 12 2010, 11:45 AM
Resident German Group: Admin Posts: 41,669 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Preload is.... If you remove the drop links all together, then lower the car, then measure between the a-arm and the sway bar ends you'll often find that each side measure differently. In order to remove all tension from the sway bar when unloaded, you may need different length (or better, adjustable) drop links to account for this difference. The bottom line is that you want the sway bar to be neutral until acted upon by outside forces. A preloaded bar is not neutral. (IMG:style_emoticons/default/agree.gif) With the car on the ground, your weight in the drivers seat, half a tank of gas both droplinks should not be loaded. With adjustable droplinks this is easy as you can turn them by hand until you don't feel any resistance and the link rotates freely. Tighten the nuts and you're done. (IMG:style_emoticons/default/popcorn[1].gif) Andy |
Lo-Fi Version | Time is now: 1st June 2024 - 07:11 PM |
