SPRING RATES, WHAT ARE THESE |
agentblr |
Mar 25 2004, 04:53 PM
Member Group: Members Posts: 303 Joined: 23-January 04 From: Lee's Summit MO Member No.: 1,595 |
THE PO SAID MY REARS WERE 100 LBS BUT THEY SURE RIDE MORE LIKE 180S THE SPRINGS ARE PAINTED BLACK BUT THEY EACH HAVE LITTLE GREEN PAINT SMEARS ON THEM,DOES THIS RING A BELL WITH ANY ONE (IMG:style_emoticons/default/confused24.gif)
Mueller |
Mar 25 2004, 05:28 PM
without measuring it is tough to know for sure.....the rough ride could be from bad/sticking bushings or from the shocks (KYB's???)
the springs come off in about 15 minutes worth of work....you can use free weights to get pretty darn close to the spring rate.... |
Dave_Darling |
Mar 25 2004, 05:38 PM
You might also consider turning off the CAPS LOCK. In some places on-line, it's considered the equivalent to shouting.
--DD |
agentblr |
Mar 25 2004, 06:13 PM
Yeah they are KYB ,called Pelican they are definetly 100lbs, shocks seem in good order,still doesnt solve my ride height problem so like a back woods boogan I cut 3 coils off ,went around the block seems to ride better evn though cutting them makes for a higher spring rates Before
Attached image(s) |
agentblr |
After
Attached image(s) |
agentblr |
Mar 25 2004, 06:15 PM
Woops wrong pic here it is After
Attached image(s) |
Mueller |
Mar 25 2004, 06:19 PM
nice looking car.....regular 914 bumpers (hopefully, (IMG:style_emoticons/default/smile.gif) ) or 916 style??
agentblr |
Mar 25 2004, 06:24 PM
Thanks, Glass bumpers from GT they should Be tommorw,cant wait as I look like a doof drivin like that (IMG:style_emoticons/default/wacko.gif)
Lo-Fi Version | Time is now: 11th June 2024 - 02:33 AM |
