took it for a spin today, sloppy shift and galloping idle? |
bcaschera |
Feb 14 2010, 07:00 PM
Member Group: Members Posts: 73 Joined: 1-October 09 From: san jose Member No.: 10,873 Region Association: None |
So despite having no roll bar, windshield, mirrors, or seat belt, I decided to take it out for a ride (IMG:style_emoticons/default/aktion035.gif) . What a blast. The only things wrong. (drivabillty wise) is that it has a sort of galloping idle and tends to want to die when i stop, and that the shifter is sloppy with a capital Y. I think that the shift problem is from worn bushings (IMG:style_emoticons/default/confused24.gif) but i dont even know if it has bushings in the linkage. As for the idle it could be anything, I haven't really checked into what it may be.... I did remove the charcoal filter and neglect to put it back on (IMG:style_emoticons/default/happy11.gif) i figure that i could just plug the in and out put where it once was ( damn ca emissions ). I am new to these cars and appreciate the wealth of knowledge on these forums. That said I am looking for trouble shooting advise, I have some idea where to look for the issues but assume i know nothing what would you advise from here? It is a 1.8 L-jet in a 75 all stock cept the exhaust, thats a Monza.if more information is needed i will gladly oblige thanks in advance. and i think i see one of these (IMG:style_emoticons/default/slap.gif) in my near future.
sww914 |
Feb 14 2010, 07:30 PM
Advanced Member Group: Members Posts: 2,439 Joined: 4-June 06 Member No.: 6,146 Region Association: None |
Shifting, bad bushings are more than common, they're ubiquitous. Hunting idle, vacuum leaks are the first place to start. Even if vacuum leaks aren't the whole problem they're still a problem almost always. Spray brakleen, carb cleaner, even WD-40 at one spot on the intake at a time. If the idle speeds up after you spray, you've found one of the leaks. Fix it and move on to the next one.
GPR has the bushings you need at a great price, they pay to advertise here. |
sww914 |
Feb 14 2010, 07:33 PM
Also, I think pelican parts has a troubleshooting guide for L-jet. The first thing it will say is probably vacuum leaks. If not google L-jetronic troubleshooting, you'll find something. Don't assume anything when troubleshooting, check it off AFTER you test that component.
silver74insocal |
Feb 14 2010, 09:11 PM
Senior Member Group: Members Posts: 736 Joined: 26-November 09 From: rancho cucamonga Member No.: 11,073 Region Association: Southern California |
you can start with this:
http://www.pelicanparts.com/techarticles/9...roubleshoot.htm see if that helps.good luck!! Dave |
Lo-Fi Version | Time is now: 15th June 2024 - 01:40 PM |
