Anyone with Paragon headers...got a question. |
biosurfer1 |
Feb 17 2010, 02:53 PM
Teener fo Life! Group: Members Posts: 3,020 Joined: 3-August 03 From: Roseville, CA Member No.: 977 Region Association: Northern California |
I have a set of the Paragon Products headers and had to take them apart for a rebuild. The gaskets that go in between the stub pipes and the header pipes are shot and I need some new ones...
Does anyone know what gasket that is? I talked with Jason there and he said it was a 911SC muffler gasket, but I can't find anything at Pelican that looks correct, except for maybe this but I want to make sure before I order. Any insight would be helpful...thanks! |
Justinp71 |
Feb 17 2010, 03:08 PM
Senior Member Group: Members Posts: 1,583 Joined: 11-October 04 From: Sacramento, CA Member No.: 2,922 Region Association: None |
The one that goes between the two red circles below?
Attached image(s) |
Justinp71 |
Feb 17 2010, 03:13 PM
If he said SC muffler gasket he probably means the gasket seen here.
http://www.pelicanparts.com/cgi-bin/smart/...0CA%20Model%252 |
biosurfer1 |
Feb 17 2010, 03:34 PM
Ya that looks like its it...
ordering now |
VaccaRabite |
Feb 17 2010, 05:00 PM
En Garde! Group: Admin Posts: 13,456 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
Yeah, thats what you want. I went through this with Paragon last summer, and they had to research the issue as they did not know what gaskets were used.
Zach |
biosurfer1 |
Feb 17 2010, 08:52 PM
Exactly what they told me too Zack...frustrating since the whole reason to have the stubs is easy on/off access to the headers
biosurfer1 |
Feb 20 2010, 04:47 PM
Well those weren't the ones I needed...too big (IMG:style_emoticons/default/dry.gif)
JamesM |
Feb 21 2010, 12:36 AM
Senior Member Group: Members Posts: 1,915 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
I found some metal ones at my local aircooled VW shop that worked.
-James |
moggy |
Apr 13 2010, 01:39 PM
Member Group: Members Posts: 192 Joined: 15-December 04 From: Wales Member No.: 3,285 |
The exhaust gaskets that fitted my header was from a 3.2L 911 engine. Fitted exactly. I found exhaust gaskets off any other 911 seemed to be too small.
Chris Pincetich |
Apr 13 2010, 01:58 PM
B-) Group: Members Posts: 2,082 Joined: 3-October 05 From: Point Reyes Station, CA Member No.: 4,907 Region Association: Northern California |
I apply a thin ring of red high temp rtv type sealant there and have had no leaks. I have done this 3 times over 2 years as I upgraded my transaxle. Why? Because nobody knows what damn gasket to put in there! I have also found, thanks to Jake R, that milk of magnesium is a great anti-seize for the hardware on the stubs, and I have numbered each of the stub bolts as I found that different spots need different length bolts to fit and numbering them makes re-assembly much smoother.
(IMG:style_emoticons/default/beerchug.gif) |
biosurfer1 |
Apr 13 2010, 02:00 PM
Ya I was able to find out they are the exhaust gaskets from a 911SC.
Chris, I tried the red RTV and had a bunch of leaks...I got new gaskets and everything seems fine now (except for tuning the stupid carbs!) |
Lo-Fi Version | Time is now: 2nd June 2024 - 02:08 PM |
