Unkown Engine Part on my 1973 2.0, Don't know what this does |
LotusJoe |
Feb 22 2010, 10:25 PM
Europa Twink Driver Group: Members Posts: 406 Joined: 30-November 09 From: Southern California Member No.: 11,085 Region Association: Southern California |
(IMG:style_emoticons/default/WTF.gif) is this? I can't find any reference in my literature on what this part is.
1973 2.0 Thanks |
76-914 |
Feb 22 2010, 10:34 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,512 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
(IMG:style_emoticons/default/blink.gif) A Turboencabulator? (IMG:style_emoticons/default/av-943.gif)
silver74insocal |
Feb 22 2010, 10:37 PM
Senior Member Group: Members Posts: 736 Joined: 26-November 09 From: rancho cucamonga Member No.: 11,073 Region Association: Southern California |
oh thats your flux capacitor (IMG:style_emoticons/default/biggrin.gif)
silver74insocal |
Feb 22 2010, 10:39 PM
haha jk. are you sure thats a 73 engine? have you checked your engine # against the database?
montoya 73 2.0 |
Feb 22 2010, 10:41 PM
Lack of consideration to others, and Selfish! Group: Members Posts: 1,791 Joined: 27-October 04 From: Paso Robles, Ca. Member No.: 3,016 Region Association: Central California |
LotusJoe |
Feb 22 2010, 10:44 PM
silver74insocal |
Feb 22 2010, 10:53 PM
does any part of it goto your engine or car other then the wires?
LotusJoe |
Feb 22 2010, 10:59 PM
does any part of it goto your engine or car other then the wires? No, Nothing connects to it. There are two small ports??? with rubber caps. I have no extra wires laying around the engine compartment. I can't find anything in either the hose diagrams or the wiring diagrams that might help identify what the heck it is. |
detoxcowboy |
Feb 22 2010, 11:07 PM
Senior Member Group: Members Posts: 1,294 Joined: 30-January 08 Member No.: 8,642 Region Association: Africa |
looks like some kind of air valve, you should already have a aux. air valvle hooked up on the otherside, 2 ports with a wire coming form it? either way it is not stock and follow the wire from it and at least let us know what is was connected too. then pull it out does not belong in a stock 73.. looks like it is grounded still and has another tab with nothing on it and the ports were sealed too, ditch it.,,
LotusJoe |
Feb 22 2010, 11:26 PM
looks like some kind of air valve, you should already have a aux. air valvle hooked up on the otherside, 2 ports with a wire coming form it? either way it is not stock and follow the wire from it and at least let us know what is was connected too. then pull it out does not belong in a stock 73.. looks like it is grounded still and has another tab with nothing on it and the ports were sealed too, ditch it.,, There was no wire connected to it. No hoses, nothing. You're right, all that is connected is a ground wire. So I can't trace any wires. I think I'll take your suggestion and remove it. |
dr914@autoatlanta.com |
Feb 23 2010, 08:50 AM
914 Guru Group: Members Posts: 7,898 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
(IMG:style_emoticons/default/WTF.gif) is this? I can't find any reference in my literature on what this part is. 1973 2.0 Thanks It is a valve to cut off the vacuum retard when the air conditioning is turned on so that the idle will not drop |
LotusJoe |
Feb 23 2010, 10:24 PM
That makes perfect sense. This car did have air conditioning. Thanks George! (IMG:style_emoticons/default/aktion035.gif) |
hot_shoe914 |
Feb 23 2010, 10:39 PM
on ramp passer Group: Members Posts: 3,802 Joined: 20-November 07 From: Earle, Ar. Member No.: 8,354 Region Association: None |
(IMG:style_emoticons/default/WTF.gif) is this? I can't find any reference in my literature on what this part is. 1973 2.0 Thanks It is a valve to cut off the vacuum retard when the air conditioning is turned on so that the idle will not drop Brilliant! Yet some people still feel the need to slam him because they order a wrong part of something. (IMG:style_emoticons/default/WTF.gif) |
oz371 |
Feb 23 2010, 10:40 PM
Member Group: Members Posts: 101 Joined: 28-August 09 From: ontario, CA Member No.: 10,739 Region Association: None |
(IMG:style_emoticons/default/blink.gif) A Turboencabulator? (IMG:style_emoticons/default/av-943.gif) It holds your turn signal fluid. (IMG:style_emoticons/default/lol-2.gif) |
bandjoey |
Feb 23 2010, 10:50 PM
bandjoey Group: Members Posts: 4,926 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
When it runs low on fluid, use your sonic screwdriver to open the refill cap (IMG:style_emoticons/default/beer.gif) and refill with your local brew. Makes the motor run realllllllly fine. And the AC runs cold. (IMG:style_emoticons/default/lol-2.gif)
Steve |
Feb 23 2010, 11:00 PM
914 Guru Group: Members Posts: 5,614 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
I believe George, but I wouldn't mess with it. It could be a weapon of mass destruction!! (IMG:style_emoticons/default/ar15.gif)
pbanders |
Feb 24 2010, 09:11 AM
Senior Member Group: Members Posts: 939 Joined: 11-June 03 From: Phoenix, AZ Member No.: 805 |
Interesting. That must jack up the idle quite a bit, even with the A/C load!
Lo-Fi Version | Time is now: 12th June 2024 - 01:00 AM |
