V8 Conversion clutch fork pivot ball & more... |
BRAVE_HELIOS |
Feb 23 2010, 08:32 PM
"Knowledge speaks, wisdom listens" Group: Members Posts: 295 Joined: 25-September 06 From: The Land Of ID! Member No.: 6,920 Region Association: Pacific Northwest |
Attention all V8 gurus!
What to do... Should I put an extra washer under the clutch fork pivot ball. Right now, it has one washer in place. (IMG:style_emoticons/default/idea.gif) Also, I read that the transaxle input shat seal cover's studs (2) should be replaced with two bolts for additional clearance. Any thoughts/opinions are greatly appreciated! (IMG:style_emoticons/default/type.gif) |
Phoenix-MN |
Feb 23 2010, 08:35 PM
Senior Member Group: Members Posts: 927 Joined: 23-January 04 From: ST. Bonifacius,MN Member No.: 1,590 |
Mine is a V6 but the same should apply and this is what I did
http://phoenixhobbies.com/html/adapter_plate.html Paul |
jimkelly |
Feb 23 2010, 09:19 PM
Delaware USA Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
i may recall wrong - but i thought the one washer needed to be removed??
jim |
Dr. Roger |
Feb 23 2010, 11:35 PM
A bat out of hell. Group: Members Posts: 3,944 Joined: 31-January 05 From: Hercules, California Member No.: 3,533 Region Association: Northern California |
i think it may vary from car to car.
try putting one washer on and bolt the transaxle to the engine and feel the play at the clutch fork. if it is very minimal then you're right on. If the tranny wont mate to the engine, take a washer out. If it mates but has excessive play, add a washer. You will use the entire throw of the clutch fork. Most i've seen actually have the throwout bearing resting on the pr. plate full time, and just not engaging. Good luck. =) |
Lo-Fi Version | Time is now: 12th June 2024 - 05:18 PM |
