> Wiring MSD 6AL to 3.0 6
bag5rcg
post Mar 8 2010, 01:38 PM
Hi Gang,
Has anybody out there wired up an MSD 6AL to a 3.0 6 with a regulated alternator?....I am afraid to play too hard with it because I don't want to start burning up components (IMG:style_emoticons/default/blowup.gif) during the effort which would lead to chasing several problems rather than one.
I also cannot get my car to do ANYTHING with the relay board attached (IMG:style_emoticons/default/WTF.gif) (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/wacko.gif) ....I am playing with the idea of bypassing the relay board all together by replacing the female style plug (on the engine side) with a male style plug that would plug into the chassis plug directly (IMG:style_emoticons/default/idea.gif) ....
Any thoughts, suggestions would be appreciated..This is the very last engineering hurdle in a 4 year restore/6 conversion
Thanks
Replies(1 - 15)
Justinp71
post Mar 8 2010, 02:35 PM
I did this last year with a internal regulated alternator. I'm not sure why it makes a difference? I thought you just connect power up to MSD and then plug the dizzy into the port on the MSD... I can take a better look tonight and let you know...
also I have seen the relay boards removed on cars with internally regulated alternators...
post Mar 8 2010, 02:43 PM
Resident German
No more relay board ...
I used a conversion harness from Patrick Motorsports. It directly connects the engine harness to the body harness plug that normally goes to the relay board.
(IMG:style_emoticons/default/driving.gif) Andy
(IMG:http://www.914world.com/bbs2/uploads/post-179-1202450158_thumb.jpg)
bag5rcg
post Mar 8 2010, 03:00 PM
QUOTE(Justinp71 @ Mar 8 2010, 01:35 PM) *
Dizzy?????...Is that an add on module?
post Mar 8 2010, 03:08 PM
Resident German
QUOTE(bag5rcg @ Mar 8 2010, 01:00 PM) *
Dizzy = Distributor
(IMG:style_emoticons/default/shades.gif) Andy
70_914
post Mar 8 2010, 03:11 PM
Dizzy = Distributor
I have hooked 6AL boxes up to VW's with generators and external regulators, VW's with internally regulated alternators, Fords with internally and externally regulated alternators. The MSD box does not care. If you look at the voltage specs it is good from, IIRC, 9-17 volts. They also have a nice fuse built in to protect it. Plug and Play!
Jeffs9146
post Mar 8 2010, 03:16 PM
Ski Bum
Is that something I should get for my 3.0L that I am putting into the 6?
post Mar 8 2010, 03:23 PM
Resident German
QUOTE(Jeffs9146 @ Mar 8 2010, 01:16 PM) *
It made for a much cleaner install. (IMG:style_emoticons/default/thumb3d.gif)
Call PMS and see if they make one for your application. Just make sure you double check the connectors/wires before you plug it in.
They had two wires mixed up on mine ...
(IMG:style_emoticons/default/dry.gif) Andy
bag5rcg
post Mar 8 2010, 03:42 PM
QUOTE(SirAndy @ Mar 8 2010, 02:08 PM) *
Dizzy = Distributor
(IMG:style_emoticons/default/slap.gif) (IMG:style_emoticons/default/biggrin.gif) Thanks
Justinp71
post Mar 8 2010, 03:47 PM
If your running carbs I wouldn't bother, the only connections on my carbed motor are to the alternator and the dizzy. If you're running CIS you might consider it if patricks even offers it. Andys motor is a motronic 3.6, so it makes more sense to use it on his application...
Scott S
post Mar 8 2010, 03:48 PM
Small Member
Drop Perry Kiehl a line. He just sent me a fantastic wiring harness for my conversion that incorporated everything from the Pertronix to the MSD in what appears to be a factory harness. It elimintes the relay board and plugs directly into the factory harness. It is SO cool...
rfuerst911sc
post Mar 8 2010, 05:47 PM
I recently picked up my 3.0 conversion from my mechanic. He used the relay board and it looks like he only added one wire to it. The factory harness is plugged into the board I guess to run other items. Also using a internally regulated alternator.
Jeffs9146
post Mar 8 2010, 07:07 PM
Ski Bum
Is it FI or Carbs?
I am going to try to run FI!
bag5rcg
post Mar 8 2010, 07:24 PM
Yep...Looking like the the new harness with the male plug is the way to go....I may check out what Perry has to offer (is he on the board??)...Thanks for all of the input!
Justinp71
post Mar 9 2010, 10:33 AM
QUOTE(Jeffs9146 @ Mar 8 2010, 05:07 PM) *
Is it FI or Carbs?
Are you refering to the factory CIS or an actual FI system?
In my opinion I would only do Motronric, carbs or a throttle body injection system. The fi systems can run good, but I hear its a lot of work and many have horror stories.
I would have loved to run motronic on my 3.0 but its requires a bit of machining to the heads, so I went with carbs! I think they're totally awesome and I get around 17-20 mpg (motronics I think get 25-30).
rfuerst911sc
post Mar 9 2010, 01:57 PM
Is it FI or Carbs?
Weber 40's
- Lo-Fi Version Time is now: 16th June 2024 - 07:48 PM
