Can I do it |
Can I do it |
904svo |
Mar 15 2010, 05:37 PM
904SVO Group: Members Posts: 1,118 Joined: 17-November 05 From: Woodstock,Georgia Member No.: 5,146 |
I want to twin plug my heads so I started today.
type47 |
Mar 15 2010, 06:29 PM
Viermeister Group: Members Posts: 4,254 Joined: 7-August 03 From: Vienna, VA Member No.: 994 Region Association: MidAtlantic Region |
70_914 |
Mar 15 2010, 06:35 PM
Member Group: Members Posts: 395 Joined: 4-December 09 From: Roy, WA Member No.: 11,096 Region Association: Pacific Northwest |
I want to twin plug my heads so I started today. What is going to trigger the plugs? Both at the same time, or 1 normal and 1 set up for waste spark? What is the inspiration for this experiment... huge compression, turbo, Nitrous.... just to say you have them? Are you welding up the stock holes and switching to newer, motorcycle style plugs with very small threads to keep hot spots and protrusions in the combustion chamber to a minimum? From an engineering standpoint just a couple general questions... Good Luck! |
agentblr |
Mar 15 2010, 06:55 PM
Member Group: Members Posts: 303 Joined: 23-January 04 From: Lee's Summit MO Member No.: 1,595 |
Looking at a bare casting right now...... looks like you would run into severe clearance issues if you try to machine the plug holes on the bottom (exhaust side) of the head. The push rod tubes are right in the way! You could machine the holes in at 45 degree angle to the existing plugs(top side) but you would have relocate the CHT bung if you were using D-jet ( I assume this is not the case) I think it is totally doable. I think you will have to add material wherever you put the 2nd plug,They just did not leave much meat in these castings. I am using a 2.0 head for reference.
904svo |
Mar 15 2010, 07:04 PM
I want to twin plug my heads so I started today. What is going to trigger the plugs? Both at the same time, or 1 normal and 1 set up for waste spark? What is the inspiration for this experiment... huge compression, turbo, Nitrous.... just to say you have them? Are you welding up the stock holes and switching to newer, motorcycle style plugs with very small threads to keep hot spots and protrusions in the combustion chamber to a minimum? From an engineering standpoint just a couple general questions... Good Luck! I configure my Megasquirt to use the twin plug Maza setup, these are going to be the test heads for my turbo. I'm planing to use Motorcycle plug on the bottom and keep the top set stock. |
agentblr |
Mar 15 2010, 07:20 PM
KEWL!! (IMG:style_emoticons/default/popcorn[1].gif)
904svo |
Mar 15 2010, 07:41 PM
Looking at a bare casting right now...... looks like you would run into severe clearance issues if you try to machine the plug holes on the bottom (exhaust side) of the head. The push rod tubes are right in the way! You could machine the holes in at 45 degree angle to the existing plugs(top side) but you would have relocate the CHT bung if you were using D-jet ( I assume this is not the case) I think it is totally doable. I think you will have to add material wherever you put the 2nd plug,They just did not leave much meat in these castings. I am using a 2.0 head for reference. The heads have to be heli arc up where the plugs are going there is not enough metal there, this will also pull the heat away. The one plug goes between the tubes the other clears with no problems. |
SirAndy |
Mar 15 2010, 07:53 PM
Resident German Group: Admin Posts: 41,675 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
The heads have to be heli arc up where the plugs are going there is not enough metal there, this will also pull the heat away. The one plug goes between the tubes the other clears with no problems. Let's see the other side! (IMG:style_emoticons/default/cheer.gif) Andy |
Lo-Fi Version | Time is now: 7th June 2024 - 03:14 PM |
