What can I use to clean Front Calipers?, Years of baked brake dust does not want to come off |
bobhasissues |
Mar 15 2010, 08:52 PM
seemingly endless issues with my 914 Group: Members Posts: 218 Joined: 13-February 07 From: Chicagoland Member No.: 7,532 Region Association: None |
Got my front calipers off, split and ready to rebuild. I cleaned the bodies relatively well with brake cleaner and a brass brush. I want to paint them, but there is still a lot of baked on brake dust that doesn't seem to want to come off. Is there something I can safely soak the caliper halves in that will dissolve the crud without damaging the internals or the mating surfaces?
tat2dphreak |
Mar 15 2010, 09:06 PM
stoya, stoya, stoya Group: Benefactors Posts: 8,797 Joined: 6-June 03 From: Wylie, TX Member No.: 792 Region Association: Southwest Region |
take them to a plater and have them bead blasted and clear cad plated.
914Sixer |
Mar 16 2010, 07:35 AM
914 Guru Group: Members Posts: 8,903 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Use a wire wheel on your grinder, drill or air tools. Make SURE you wear a dust mask and face shield.
Pat Garvey |
Mar 16 2010, 06:21 PM
Grinding & clear coat is NOT rebuilding. Send them to Eric Shea!
Krieger |
Mar 16 2010, 06:57 PM
Advanced Member Group: Members Posts: 4,726 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
I am going to be doing the same as you. I am considering soaking one in turpentine or laquer thinner and seeing what happens. I have both of these in my garage that is why I'mt rying these. I am not planning on painting or replating.
Cairo94507 |
Mar 16 2010, 07:10 PM
Michael Group: Members Posts: 9,822 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
Just based on what I have seen here, when it comes to brakes, it begins and ends with Eric. Personally, when I do the calipers on my car they are only going one place. I don't want any mistakes or screw ups on the only real safety feature these cars have. Just my 2 cents.
bobhasissues |
Mar 16 2010, 08:29 PM
Grinding & clear coat is NOT rebuilding. Of course it's not, don't be a douche. Just based on what I have seen here, when it comes to brakes, it begins and ends with Eric. Personally, when I do the calipers on my car they are only going one place. I don't want any mistakes or screw ups on the only real safety feature these cars have. Just my 2 cents. Eric's work is fantastic and I got some of my replacement parts from him. I won't be the last person to successfully rebuild a set of calipers. I did a complete teardown and rebuild of the rears (which are far more difficult) three years ago. I am going to be doing the same as you. I am considering soaking one in turpentine or laquer thinner and seeing what happens. I have both of these in my garage that is why I'mt rying these. I am not planning on painting or replating. Tonight I tried my Spot Blaster, with baking soda as the blast media, and it worked extremely well. Grime is gone, and no harm to the cylinders or mating surfaces. |
Lo-Fi Version | Time is now: 7th June 2024 - 05:52 PM |
