Wiring Help Needed - Side Marker Light Delete, I Wish They Made a Schematic for the '74 |
kconway |
Mar 16 2010, 09:13 PM
Senior Member Group: Members Posts: 1,347 Joined: 6-December 04 From: Monrovia, CA Member No.: 3,231 Region Association: Southern California |
I'm having a tough time understanding the current flow diagram for the '74 and need a little help.
I've removed my side marker lights and would like to pull the wires that use to feed the marker lights if possible. I can't really tell but it looks like the hot wire also feeds the parking light. Can someone confirm? Are the two spliced back somewhere in the harness or is that connection in the parking light? Kev I'd like it to be this clean...photo courtesy E. Shea |
76-914 |
Mar 16 2010, 10:40 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,508 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
I'm having a tough time understanding the current flow diagram for the '74 and need a little help. I've removed my side marker lights and would like to pull the wires that use to feed the marker lights if possible. I can't really tell but it looks like the hot wire also feeds the parking light. Can someone confirm? Are the two spliced back somewhere in the harness or is that connection in the parking light? Kev I'd like it to be this clean...photo courtesy E. Shea You have 2 hots to the bucket. One is for turn signal and the other is for the parking lamp. There is a 3rd wire for the side marker lamp. Side marker wire colors should be GY/BK for the left side lamp/left parking lite........ and GY/RD for the right side, ditto. Left frt turn wire should be BK/WH.........and BK/GR for the right side. Hope this helps |
kconway |
Mar 16 2010, 11:06 PM
So do the GY/BK and the GY/RD from the side marker lights go all the way back to the fuse block?
jt914-6 |
Mar 17 2010, 05:04 AM
Driving & working on teeners 41 years Group: Members Posts: 1,786 Joined: 3-May 08 From: Bryant, Arkansas Member No.: 9,003 Region Association: South East States |
You can go here and use the '73 wiring diagram to follow the wiring....
http://www.pelicanparts.com/914/914_electrical_diagrams.htm |
kconway |
Mar 17 2010, 08:29 AM
You can go here and use the '73 wiring diagram to follow the wiring.... http://www.pelicanparts.com/914/914_electrical_diagrams.htm Great idea, thanks. I guess I should have figured the '73 and '74 didn't change much in the wiring for the lights. So, if I understand it correctly, both wires to the side marker lights can be removed or cut and shrink sleeved without effecting the running lights. It appears the turn signal bucket has a dedicated ground for both directional signal and running light? |
Lo-Fi Version | Time is now: 8th June 2024 - 07:55 AM |
