Fuel pump location, on a 72 |
jeffdon |
Mar 18 2010, 04:57 PM
Senior Member Group: Members Posts: 1,094 Joined: 24-October 06 From: oakland, ca Member No.: 7,087 Region Association: None |
My 72 never had the FI pump under the tank. Car is now carbed, and I am thinking of mounting my carter pump up front. Wheres the easiest place to find a keyed positive?
Also, fuel lines are original. With the pump in the engine bay, i figured that there was not much pressure on them, as the pump was operating to suck the fuel up the line. IF i put it up front, then there will be pressure on the supply lines. Am I creating a situation where leaks are more likely? |
TheCabinetmaker |
Mar 18 2010, 06:04 PM
I drive my car everyday Group: Members Posts: 8,304 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
Only 75/76 had fuel pump in front. Carbs? No advantage to moving it that I can see. I'd bet there is something a lot more useful you could spend your efforts on.
Joe Owensby |
Mar 18 2010, 07:08 PM
JoeO Group: Members Posts: 527 Joined: 7-January 06 From: Spartanburg, SC Member No.: 5,385 Region Association: South East States |
Tha main reason to move the pump to the front is to minimize issues with vapor locking of the pump due to engine heat on hot days. If you move it, I suggest you install a power relay. Supply main power to the relay from the battery feed. Then use switched power from the fuse box to turn the relay on. This keeps the current needed to feed the fuel pump from having to go through the switch. The main thing is to make sure that all lines you install are fused. I ran a new main power wire from the battery, using a fusable link at the battery, into the area under the dash. I then put individual fuses to supply power to the fuel pump, and also to an AC unit that I installed. If you do a search here or on PellicanParts, there are details.
markb |
Mar 18 2010, 09:04 PM
914less :( Group: Members Posts: 5,449 Joined: 22-January 03 From: Nipomo, CA Member No.: 180 Region Association: Central California |
Have you had a problem with vapor lock in the past? If not, I see no reason to relocate it. I have carbs on my current motor, mounted in the stock 72 position, and put an aluminum plate in front of it as a keat shield. Haven't had an issue since I put it in.
jeffdon |
Mar 18 2010, 10:00 PM
Have you had a problem with vapor lock in the past? If not, I see no reason to relocate it. I have carbs on my current motor, mounted in the stock 72 position, and put an aluminum plate in front of it as a keat shield. Haven't had an issue since I put it in. none in the past, was just thinking of cleaning up the motor bay. |
914Sixer |
Mar 19 2010, 06:57 AM
914 Guru Group: Members Posts: 8,903 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Fuel pump should be mounted under the engine shelf from the factory not in the engine compartment.
Lo-Fi Version | Time is now: 8th June 2024 - 10:42 PM |
