Suggestions for Fuel Injection, For a dedicated track car |
nine14cats |
Mar 29 2004, 12:23 AM
Bill Pickering -- 914-6 GT aka....Leeloo Group: Members Posts: 2,618 Joined: 10-February 03 From: Campbell, CA Member No.: 287 Region Association: None |
What are my options for a fuel injection system for my track only car? The car will never see the street again and the engine is a purpose built race motor.
It is a 2.7 L 6 cylinder, 10.5:1 compression, head work, cam, recurved disty, MSD 6AL ignition with adjustable rev limiter, triple throat carbs. See my post on diagnostic help for carbs for the reason I'm asking.... (IMG:style_emoticons/default/laugh.gif) Thanks, Bill P. |
Brad Roberts |
Mar 29 2004, 01:05 AM
3.2 upper intake all the way with laptop programmable injection. Pick your poison. Lots of good systems out there.
B |
ChrisReale |
Mar 29 2004, 01:11 AM
Sleazy Group: Members Posts: 2,665 Joined: 20-January 03 From: San Francisco Member No.: 176 |
Greg Fordahl has a 2.8 with Motec (not his car, but he drives the shit out of it). That car smokes
Brad Roberts |
Mar 29 2004, 01:17 AM
The carbs would almost pay for a TECIII brain new in the box. Hopefully you didnt yank your return line.
B |
seanery |
Mar 29 2004, 08:52 AM
waiting to rebuild whitey! Group: Retired Admin Posts: 15,854 Joined: 7-January 03 From: Indy Member No.: 100 Region Association: None |
when I first started the bluecar project Richard Clewett gave me a ballpark of 3k for everything. If you already have manifolds, those can be reused as well as some other items. If you can recoup 1500 or so with your carbs, it seems like a good deal, and you get spark management as well.
Qarl |
Mar 29 2004, 08:55 AM
Shriveled member Group: Benefactors Posts: 5,233 Joined: 8-February 03 From: Florida Member No.: 271 Region Association: None |
On the Pelican Parts 911 board here is a turnkey FI kit using the Megasquirt injection system.
You do need the stuff for CIS injection (manifolds, airbox, and throttle body), but that can be had for cheap. http://forums.pelicanparts.com/showthread....threadid=139422 |
seanery |
Mar 29 2004, 09:17 AM
Brad & I discussed this for a -4 once, and I think I remember hearing that the frequency of the Megasquirt isn't either fast enough or consistent enough for a race car. Someone correct me if I'm wrong, or fill in with proper info.
Qarl |
Mar 29 2004, 09:26 AM
Mark Henry |
Mar 29 2004, 09:54 AM
Of course I like the SDS system. (IMG:style_emoticons/default/wink.gif)
A complete /6 system with crankfire (or a MSD trigger for a bit less coin) can be had for under 2K. You still need the TB’s, manifolds injectors, pump etc. Dual plug, turbo or N/A. There’s a couple of 911’s on the project page and I’ve added a sample map of a 3.2 N/A for you. www.sdsefi.com It also has links to the other systems on the site. What I’ve been told is if your going to race Megasquirt may not be for you. Many feel the fuel and spark tables are a little too small for extreme set-ups. They are a 8x8 matrix, and I believe SDS is a 16x16. Attached image(s) |
nine14cats |
Mar 29 2004, 09:59 AM
Thanks for all the input and keep it coming. I'll probably stop by HPH at lunch today and talk over some options.
If I could have, I would have gone injection from the get go, but I fell into the race motor that alreay had the carbs as part of it. And when the carbs are dialied in, the motor rocks! (IMG:style_emoticons/default/aktion035.gif) The problem is something with the fuel delivery and tonight after work I'll start opening things up to take a look see....but I do have to fiddle with the carbs quite a bit and I think I want to go FI. Let's see....my list of projects to work on the race car that I've already said I won't change is: 1. FI 2. WEVO 915 3. Mueller's roller bearings 4. 930 brakes geez....I'm such an addict.... (IMG:style_emoticons/default/barf.gif) (IMG:style_emoticons/default/laugh.gif) Bill P. |
Lo-Fi Version | Time is now: 28th May 2024 - 06:22 PM |
