NPC: Replace Catalytic converter, On my truck-should I? |
URY914 |
Mar 29 2004, 08:20 AM
I built the lightest 914 in the history of mankind. Group: Members Posts: 120,758 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
My catalytic converter on my Dodge Ram is coming apart and raddling around. If it continues I'm told, it could screw up the muffler and clog the pipes. The truck has 108,000, so it is out of warrenty.
So the questions are: a. Do I be a good friend of the Earth and spend +/-$500 to have it replaced? b. Replace it myself, can't be that hard right? c. Do I replace it with a stright pipe for $20, screw Mother Nature and pocket the change? Is there other options? Whata think? Paul |
GWN7 |
Mar 29 2004, 08:30 AM
King of Road Trips Group: Members Posts: 6,280 Joined: 31-December 02 From: Winnipeg, MB, Canada Member No.: 56 Region Association: Northstar Region |
Here you can't sell it if the original equipment is missing. Think aftermarket. You should be able to find a aftermarket unit for a lot less.
seanery |
Mar 29 2004, 09:05 AM
waiting to rebuild whitey! Group: Retired Admin Posts: 15,852 Joined: 7-January 03 From: Indy Member No.: 100 Region Association: None |
c. (but don't tell anyone)
Rusty |
Mar 29 2004, 10:40 AM
Wanted: Engine case GA003709 Group: Admin Posts: 7,941 Joined: 24-December 02 From: North Alabama Member No.: 6 Region Association: Galt's Gulch |
C.
Then drive it until it falls apart. For a Dodge, that should be a good long time. -Rusty (IMG:style_emoticons/default/smoke.gif) |
SLITS |
Mar 29 2004, 01:07 PM
"This Utah shit is HARSH!" Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
If you don't have bi or annual smog checks - gut the puppy and continue on down the road. Fuck the tree-huggers and Spotted Owl Lovers (Spotted Owl makes a great sandwich). Replace it when you sell it. If ya wind up junkin' it - don't bother.
tat2dphreak |
Mar 29 2004, 02:43 PM
stoya, stoya, stoya Group: Benefactors Posts: 8,797 Joined: 6-June 03 From: Wylie, TX Member No.: 792 Region Association: Southwest Region |
QUOTE(Lawrence @ Mar 29 2004, 10:40 AM) C. Then drive it until it falls apart. For a Dodge, that should be a good long time. -Rusty (IMG:style_emoticons/default/smoke.gif) (IMG:style_emoticons/default/agree.gif) if your state has a "visual" inspection (like most of TX) you can take the cat-converter and jam a straight pipe THROUGH IT... it will still pass VISUAL inspection... you are screwed if they switch to a full(hooked up to a dyno-looking machine) inspection, you are screwed... but if you *want* to do it "right" (IMG:style_emoticons/default/rolleyes.gif) it's not hard to replace. |
Dave Bell |
Mar 29 2004, 03:05 PM
Member Group: Members Posts: 234 Joined: 27-November 03 From: Santa Clarita, CA Member No.: 1,398 Region Association: None |
I had to do the CAT on my 75 teener one more time last year... rolls into the 30 year CA exemption after that.
I picked up an after market unit for about $90 at a FLAPS and welded it in myself... I imagine that it wouldn't cost more than about $50 - $70 to get a cheap muffler shop to do the same welding... total cost would likely be less than $200 for whole thing done by a muffler shop if you let them source the CAT. I doubt that the remains of the little platinum coated catalytic screens, blown into the muffler, would clog it up... but someone else may have had a bad experience. The little screen bits from the converter can and will stay in your muffler and can rattle a bit in there..... On my 914, its really hard to hear the rattle of a few tiny pieces of metal in the bottom of the muffler... on your Dodge it may be different. If you have to pass smog... you will likely have to fix it before the test. |
anthony |
Mar 29 2004, 03:37 PM
2270 club Group: Benefactors Posts: 3,107 Joined: 1-February 03 From: SF Bay Area, CA Member No.: 218 |
Is there a smog check in your area?
Personally, I'd be inclined to do the right thing and replace the cat - with a much cheaper aftermarket unit. Afterall, you have to breath the air too. |
URY914 |
Mar 29 2004, 06:34 PM
Thanks everyone for your input. I called around to a few muffler shops and if I go with a univeral cat unit it will be in the $200 range. I really didn't want to do it myself. I'll do anything to my 'teener but when it is the truck, I'll pay others to get dirty.
And to answer the question on the inspection issue, Florida doesn't have emission tests. Thanks again Paul |
Lo-Fi Version | Time is now: 23rd May 2024 - 03:42 AM |
