> HELP! 914 Voltmeter VDO Gauge connection, Where do you connect the voltmeter VDO to get the best reading?
recko911
post Mar 21 2010, 09:36 PM
Can anyone let me know where do I connect the Voltmeter VDO Gauge so I can get the best reading... I am not to familiar with the electronics.. Is it in the fuse panel thanks...
Replies(1 - 2)
Mike Bellis
post Mar 21 2010, 09:54 PM
Resident Electrician
QUOTE(recko911 @ Mar 21 2010, 08:36 PM) *
Can anyone let me know where do I connect the Voltmeter so I can get the best reading... I am not to familiar with the electronics.. thanks...
For the best reading, run new wires to your battery. Any 12V+ switched wire will give you a good enough reading. Automotive voltage gauges do not have a fine enough callibration to worry about. You can compare the reading with a digital voltage meter (like a Fluke).
Just make sure your system reads between 13-14 volts at 2000 rpm. Most vehicle electrical charging systems do not make good voltage below 1500 rpm.
Cap'n Krusty
post Mar 21 2010, 10:24 PM
Cap'n Krusty
The battery is the best place, but you'll need to run it through a relay or it'll be on all the time. The Cap'n
- Lo-Fi Version Time is now: 7th July 2025 - 07:45 AM
